Mirror construction involves left hand threads on 2012+ 650s and 2014+ 1000s - Page 3 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
post #21 of 37 Old 06-18-2015, 09:45 PM
GregB's Avatar
Originally Posted by Dave MP View Post
Try this one
Attachment 118881
Thanks
2014 650 Glee
GregB is offline
post #22 of 37 Old 09-21-2015, 09:37 PM
Loosen the top nut by turning it clockwise as you look down on it and swivel to stalk where you want it. Then tighten the nut in the other direction. You may need to hold the bottom part in place for the final tightening as it can loosen if you turn the top nut too hard.
OK I must be really stupid cause I can't figure this out.
I assume you are referring to the *bottom* nut in the second sentence?
My issue is I get the mirror where I like it but the bottom nut isn't tight. Tightening it without moving the stalk doesn't work as both nuts move together. I'm stuck with one mirror off 90 degrees where it should be or flopping around completely loose. Wtf???
plutoz is offline
post #23 of 37 Old 09-21-2015, 09:52 PM Thread Starter
You need to loosen the top nut from the bottom nut. Then tighten the bottom nut to the mount. Finally, tighten the top nut.
post #24 of 37 Old 09-21-2015, 10:33 PM
Yeah, I finally got it. What a PITA. And I have a nice scratch on my signal mount box to show for my efforts. At least now my mirrors shouldn't come spinning around every time I hit a bump.
plutoz is offline
post #25 of 37 Old 09-22-2015, 07:35 AM
pudge84's Avatar
I found this out the hard way. Luckily there is a nice rubber boot covering it up.
pudge84 is offline
post #26 of 37 Old 10-04-2015, 10:54 PM
Yeah, that left hand thread was driving me crazy so I gave up trying to loosen it. Now I know!
rambunkshuss is offline
post #27 of 37 Old 01-17-2016, 08:35 PM Thread Starter
I just found out the Vee2 uses the same mirrors so this thread gets moved to the general forum and re-titled.
post #28 of 37 Old 06-08-2016, 07:37 PM
just discovered this today! glad i could confirm it here, thanks!
tfro33 is offline
post #29 of 37 Old 07-31-2016, 12:58 AM
sillyboy's Avatar
I accidentally figured this out today when I added mirror extenders. Wish I had noticed this thread earlier.
sillyboy is offline
post #30 of 37 Old 04-06-2017, 05:13 PM
robfilms's Avatar
does the above left hand/right hand mirror threading apply to a 2009 dl650/wee?
sorry for the noobie question.
better to ask then wrestle, strip the bolt and wonder why i didn't ask beforehand!
thanks in advance.
be well.
rob
2013 Yamaha FJR1300 - Stone Grey
2009 Suzuki DL650 Wee-Strom - Le Grande Orange
2006 Kawasaki Z750S black
1974 Yamaha RD350 maroon with a white racing stripe!
robfilms is offline
