Mirror construction involves left hand threads on 2012+ 650s and 2014+ 1000s - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
post #11 of 37 Old 12-23-2013, 12:24 AM
DesertWee-Strom's Avatar
what is the easiest method to adjust the stock mirror
2004 BMW 1150 GS Adventure
2012 Suzuki DRZ 400s
2013 Wee-Strom
DesertWee-Strom is offline
post #12 of 37 Old 12-23-2013, 12:50 AM Thread Starter
Loosen the top nut by turning it clockwise as you look down on it and swivel to stalk where you want it. Then tighten the nut in the other direction. You may need to hold the bottom part in place for the final tightening as it can loosen if you turn the top nut too hard.
post #13 of 37 Old 10-08-2014, 01:57 AM
Duh!, Thanks very much for that, just bought a new 650, and was trying to adjust the mirrors and couldn't work out why it wouldn't loosen, the mirror came off the bar mount ok, as that was RH thread, but no idea that the adjuster was LH, thought I'd leave it in case I stripped it. Thanks again very much.
axeman1966 is offline
post #14 of 37 Old 01-25-2015, 12:34 PM
Stromtrooper.com Sponsor
richlandrick's Avatar
The information in the thread above about the threads for the right piece in the first picture is incorrect. This is the piece that screws into your mirror stalks mounted on your handlebars.
The thread is M10 x 1.125. Not M10 x 1.5 It is a normal right hand thread.
M10 x 1.5 is very common and can be found in most hardware stores. M10 x 1.25 is less common, but still available. Use of M10 x 1.5 bolts will damage the female threads in mirror stalks.
I don't know of any mirrors that use an M10 x 1.5 thread so if your replacing your mirrors the point may be moot.
Mirror Extenders - AdventureTech, LLC.
richlandrick is offline
post #15 of 37 Old 01-25-2015, 01:37 PM
Satch's Avatar
M10 X 1.125 ? I think you mean M10 X 1.25 correct?
:arrow: Follow the V-Strom Cache Adventure | See Where the Cache has Been | Play the Stromtrooper Picture Game | Play the Weekly Picture Game
Preferred V-Strom Model Nicknames: 02-12 DL1000 Vee, 2014+ DL1000 ABS Vee2, 04-11 DL650 Wee, 12-16 DL650 Wee2, 17+ DL650 Wee3
V-Stroms I've owned: Wee.07, Wee.11, Wee2.13. Currently Wee-less
Satch is offline
post #16 of 37 Old 01-25-2015, 01:46 PM Thread Starter
Good catch. I edited the post.
post #17 of 37 Old 01-25-2015, 10:10 PM
Yep. M10 x 1.25
post #18 of 37 Old 06-16-2015, 05:18 AM
GregB's Avatar
Ok sorry to be acting a bit dumb but I've logged in and out,refreshed as well as changed threads and I still can't see the pic in the the first post????
2014 650 Glee
GregB is offline
post #19 of 37 Old 06-16-2015, 09:11 AM Thread Starter
It's still there. Are you possibly at a work computer? Sometimes IT sets them up to deny access.
post #20 of 37 Old 06-16-2015, 09:55 AM
Dave MP's Avatar
Try this one
Dave MP is offline
