More curious than anything else, but I've always wondered if the strom's fuel injection is sophisticated enough to cut fueling on negative load - for example, when engine braking down a hill.
Isn't fuel injection unlike a carburetor that took gas on vacuum and a diaphragm pump, fuel injection feeds on demand from sensors.
My other injected bike says I'm getting up to 199 PMG when going down hill throttle off.
I would think the only sensor that could do that is the throttle position sensor. If it's closed it is going to shut down the injectors, hence the huge engine braking the Strom has. GW might think otherwise but it makes sense to me.
It is not a sensor that take "decision". It is the ECU by collecting information from various sensor, trottle positon, temperature, manifold pressure, actual RPM, actual speed, etc.
Since we're discussing the Strom's FI... does the Strom adjust mixture for changes in elevation? (If it does, do all FI systems do this?) Does this require oxygen sensors, and do the Stroms have 'em?
You say the right thing, oxygen sensor. The reason for oxygen sensor is act as feedback to the ECU, that continually ajust the fuel delivery in the cylinder to maintain the proper ratio of air/fuel. If my memory is good in automobile engine it is somewhat like 14.7:1 ratio (mass, not volume). So in less dense air the ECU compensate.
I played around with it in the past on my 2012 and it definately cut off, I think it was somewhere above the 2000 to 3000 rpm range and kicked back in in the 2000 to 1800 rpm range. (I know it did just can't remeber what rpm's it did it at.) If you close the throttle above, say, 2000 rpm with a warm engine while riding (lets say in 3rd) and don't touch the throttle until idle speed you can feel a very subtle little surge at the rpm it turns back on at. I am not sure where that was and it is subtle so you may need to try it a few times to be sure when it happens.
..Tom
Related Threads
StromTrooper
1.7M posts
66.6K members
Since 2003
