I have built and I am testing a throttle lock/cruise control for my 2008 Wee.
I would like to know what other year models and bikes use the same throttle and switch gear as the 2008 Wee.
I has the two cables and between the cables is a plate the keep the cables in place and a Phillips head screw to hold it all.
What I have built is a bolt to replace the Phillips head screw, it has a spring loaded tip to apply pressure to the throttle tube and can be adjusted while ridding.
If it works out after long term testing I will try to post photos, I'm better with hand tools than computers.
