Help - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Florida Troopers The forum for Florida V-Strommers, meet and greet ride dates, etc.
post #1 of 8 Old 03-07-2010, 08:24 AM Thread Starter
My Strom's Avatar
Help
I am feeling some excessive vibration in the foot pegs and hear a little clunking while moving the bike. the chain and sprockets only have 11,000 miles on them and is always well lubed. At 57,000 miles is it possible for the cush drive to fail?
The rear sprocket can be moved about 1/8" of an inch in either direction while on the side stand. Is this normal?
Thanks, MyStrom
2006 DL 1000 Gray and Black:
Corbin seat with backrest ,Givi wind screen with Mad Stad Mount, Givi crash bars, Whelen 500 series brake/warning light, Whelen hand guard turn signals, 55w Hella running lights, Black reflective swing arms and reflectors…………
My Strom is offline
post #2 of 8 Old 03-07-2010, 09:15 AM
ironmorph's Avatar
Send a message via AIM to ironmorph
I am no expert,but your cush drive dampers are probably well worn at 57K. I would take a close look at tire wear, are wheel weights missing or poorly balanced wheels? Has your chain been checked for alignment recently? Measuring both sides will reveal. Have you checked wheel bearings recently? Have you checked final drive bearing?
just suspect items,
Clem
ironmorph is offline
post #3 of 8 Old 03-08-2010, 09:33 PM Thread Starter
My Strom's Avatar
Thanks for the advise Clem. Upon futher inspection the Chain does have a few links that may be kinking. A definite tight spot so I will replace the chain first.
My Strom
My Strom is offline
post #4 of 8 Old 03-09-2010, 03:59 PM
pinkman's Avatar
My Strom
Hey My Strom. I agree with replacing the chain.
57K does seem like a lot of miles for cush dampers. With close to the same miles I've just replaced mine a second time. They are relatively cheap and easy to change.
Greg "Pinkman" Pink
Leesburg, FL
K4, Flat Black Club #135
pinkman is offline
post #5 of 8 Old 03-11-2010, 07:15 AM
instructorpilot's Avatar
don't forget to change the sprockets as well. If you want to use the lift let me know. Maybe we can sync mine while your here.
A
DL1000, CB750F, CX500, GL500, GL1100 (2)
instructorpilot is offline
post #6 of 8 Old 03-16-2010, 10:11 PM
toycloser's Avatar
I have 47k miles on mine and the new drive cushons will be here on Thursday. I'll post up after install.
2007 Aprilia Tuono (black) 20k
2005 Suzuki V-strom (black) 53k, still going...
notice a trend?
toycloser is offline
post #7 of 8 Old 03-16-2010, 10:37 PM
The sprocket carrier bearing , cush rubbers and the chain protector around the front of the swingarm are often toast well before that mileage on 1000s.
post #8 of 8 Old 03-19-2010, 08:19 PM Thread Starter
My Strom's Avatar
RE: Help
Thanks for all the suggestions guy's! All parts are on order and will be in the shop next week. (Full Spectrum Racing)
My Strom is offline
