Suzuki hard luggage keys - Page 4 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Feedback to Suzuki Only post information that you feel Suzuki would benefit from knowing. Not a "conversation" section
 4Likes
post #31 of 34 Old 07-19-2017, 03:02 PM
My new 2018 DL1000 came with 3 lock cylinders. When the luggage (finally) arrived the dealer installed the cylinders in the new luggage and now everything works from the ignition key.
Don't lose the ignition key. I did once, and found that the code was stamped on the underside of the gas filler cap. Took the locksmith 2 hours to pick that lock. Bill
Lrobby99 likes this.
wkprather is offline
post #32 of 34 Old 01-19-2019, 02:34 PM
For the record, these are the blanks you have to choose from for OEM plastic hard cases for the 1st generation 650s. An earlier post confirmed that the Silca blank works. I can personally confirm the JMA ones work. Just successfully had a FI-13 cut.
brock29609 is offline
post #33 of 34 Old 01-21-2019, 03:08 PM
bighammer's Avatar
My local hardware store (DeWeese Do-It-Best) has cut keys for my 2004 SV650 and my 2018 DL1000 from in-stock blanks. The new one is more recessed, so I had to modify the head of it abit, but they are both from the same Ilco X241 SUZ18 blank. (just checked and it does fit the cylinders that came with my new Strom)
2018 Flee-Strom 1000XT
bighammer is offline
post #34 of 34 Old 01-21-2019, 04:04 PM
Yeah, if we're talking Wee ignition, fuel cap and seat release key holes, these blades work but many models can't use the square head in the ignition without reshaping them. Not a prob with the Ilco X276 SUZ16 blank.
