center stand - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Feedback to Suzuki Only post information that you feel Suzuki would benefit from knowing. Not a "conversation" section
post #1 of 10 Old 05-06-2011, 11:28 AM Thread Starter
center stand
Put a damned center stand on the bike stock, what heck is wrong with these idiots? Chain drive bike and here I am fighting the @!#!! springs, should have been done in the factory. I love this bike, but this is crap!
I eliminated the words I really wanted to use btw.
Bill H.
griffin800 is offline
post #2 of 10 Old 05-06-2011, 11:53 AM
papachiax6's Avatar
were you able to get the spring on? There are a few tricks, one is to tie a heavy string to the hook part of the spring and then run the string through the spoke of the rear wheel and secure. Roll your bike to tension the spring to the post. Although you can accomplish with one person, two people make it easy simple. Couple of minutes and you are good to go.
papachiax6 is offline
post #3 of 10 Old 05-06-2011, 12:41 PM
CanadianFZ6's Avatar
Bill H.
That's because you are not using a simple trick... I am quoting someone below...
What's the trick? A long nylon boot lace!
1. Roll the bike until a spoke on the rear wheel is vertical and down.
2. Brace the centerstand in the 'up' position (I used a couple of to be recycled tin cans).
3. Use a bowline knot to tie one end of the bootlace through the hole in the spoke
4. Attach the springs to the frame side stud.
5. Loop the lace through the U at the end of the small spring.
6. Brace your foot against the front tire and pull on the lace toward the back of the bike.
7. The U on the end of the spring will act as a pulley giving you a mechanical advantage of two. And it will guide the spring end into the slot!
8. Do the same thing with the large spring. I used leather gloves to pull the lace for the big spring.
Didn't marr the spring, wheel, pipes, or centerstand. The big spring took a good pull, but I'm not exactly superman either ;D
Hope this helps someone...
2015 DL650AL5 in Blue
CanadianFZ6 is offline
post #4 of 10 Old 05-06-2011, 02:23 PM
hamblinc's Avatar
Send a message via AIM to hamblinc Send a message via Skype™ to hamblinc
I just installed the SW-Motech Center stand today. The spring was not that bad to get on for me and i just used flat head screw driver. I love it so far
Motorcycling is a lot like life:
What's the point if you don't enjoy the ride?
hamblinc is offline
post #5 of 10 Old 05-06-2011, 02:28 PM
enumclaw's Avatar
Use one of these and it takes about 30 seconds.
Rob
Ride every day, it's good for you.
07 650A | KLR250(x2) | KLR650 | DRZ400 | FJR
enumclaw is offline
post #6 of 10 Old 05-06-2011, 02:33 PM
gryphon51's Avatar
My thoughts exactly......
gryphon51 is offline
post #7 of 10 Old 06-03-2011, 12:58 AM
SpecVstrom's Avatar
That is exactly what I used. It was easy. Don't try to use the pliers part. Slip the end of the spring on the handle near the end with the cupped recess. Angle the handle and put the cupped end on the pin. Then pry the spring up and on.
DL1000K9
2014 Triumph Tiger Explorer
2003 Nissan Sentra SE-R SpecV
2014 Ford Focus Electric
And, the FFE costs the least per mile to fuel!!!
SpecVstrom is offline
post #8 of 10 Old 06-06-2011, 08:47 PM
garvinzoom's Avatar
I tried the brake tool as pictured above and after about dropping the bike on my face and cussing like a sailor I took the pivot bolts back out and worked it together with the spring on first. I tried everything I could think of to get those springs on....
2011 DL650 (The Ghost)
1999 Suzuki Bandit 1200 (The wife's rocket)
garvinzoom is offline
post #9 of 10 Old 06-07-2011, 03:20 AM
banditrider's Avatar
I used a loop of string (doubled over for strength) and had a mate hold the stand up (bike was on blocks, hanging from ceiling). It was far better than attempt 1 (pliers), attempt 2 (screwdriver) and attempt 3 (fishing line - broke too easy).
Hopefully there won't be a next time but I've saved the piece of string...
'08 Vee: Suzy luggage, Crash bars, Rad Guard & front mudguard extension, Zumo 550, Oxford Hot grips, Stebel, PC-8, 12v acc, Scott oiler & lube-tube, Remus Revolution Cans, Bark Busters, Phillips Extreme vision +100 bulbs.
'08 Concours 14: Rad guard, Stebel, Oxford Hot grips, Projekt D Screen, Hugger, GPS mount, helmet locks & front guard extension, Zumo 550, Stebel, Phil's rack & Givi V46, Sheepskin seat cover, Phillips Extreme vision +100 bulbs.
http://banditrider.weebly.com/index.html
http://banditrider.blogspot.com/
banditrider is offline
post #10 of 10 Old 06-07-2011, 05:15 AM
OZ STROM's Avatar
I mounted my Suzuki centre stand (no dramas)bought new on E Bay $75.00 Aus: then came the springs issue ,found the easiest solution ,zip tie the stand in position rode down to my Suzuki dealer ,had a coffee in the cafe' springs fitted no worries .
I RIDE A STROM .Suzuki V Strom when only the BEST will do.
OZ STROM is offline
