Suzuki quality assurance failure - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Feedback to Suzuki Only post information that you feel Suzuki would benefit from knowing. Not a "conversation" section
post #11 of 31 Old 08-14-2010, 02:46 PM
I'm having a problem with the replacement ECU (posted elsewhere). It lasted a little over a year, now it is NFG. I have gone over every single sensor test and adjustment and the bike runs like crap under 4,000 rpm, WORSE than it did before the swap.
I installed a borrowed STOCK MAP ECU and the bike runs MUCH BETTER!! Obvious conclusion is the replacement ECU is defective. American Suzuki is basically saying Tough sh!t. Something ELSE must be wrong with your bike. It's CAN'T be the ECU. You are out of the basic warranty and emissions warranty." I knew that and asked for a "goodwill gesture."
I got a gesture alright!! It as F you!!
Does anyone know how to get past the "customer service secretary" and have a qualified and authorized person help me? Fortunately I'm in a position where I can drive to Corporate and have someone ride my bike. Then they could install a new ECU and drive my bike and notice the HUGE improvement. That would be so awesome!!! Do you think they would "good will" an ECU???????????
.....sigh.
Well this fight ain't over yet, I can tell you that right now!!
EDIT: (8-16-10) Basically saying that I'm out of warranty, Suzuki has made their final decision to extend some goodwill to me by EXTENDING THEIR MIDDLE FINGER!!
Thanks Suzuki!!!
The grass may look greener, but there is probably more POOP in it!
Columbo is offline
post #12 of 31 Old 10-05-2010, 12:05 PM
This is really bad as it looks like a Quality Assurance issue and I can realize it more than anybody else because I am also a QA guy.
My field is software but QA is QA, no matter for what product its being performed. The Quality Assurance department must adhere all well-defined processes in order to make sure that nothing is left that may cause a product defect at any stage. Must look for a motor bike from top to bottom with respect to the different stages of production and even test it using some weighing software that its perfectly scaled.
You must get the bug fixed by Suzuki, otherwise, it will be a really bad show.
stevenfisher is offline
post #13 of 31 Old 10-06-2010, 03:55 PM
My magnets in my stator rotor did the same. The shop asked "What oil did you use?" The look that I gave them let them know that I am nobodies fool! I found some parts online and fixed it. Suzuki is a pain sometime but I love my Vstrom. What da ya gonna do?
sdyer is offline
post #14 of 31 Old 09-13-2011, 06:43 PM
Bahill's Avatar
Magnets sliding/separating from the rotor
I Just wanted to document another case of the rotor magnets sliding out of place in the rotor assembly. After having electrical charging issues with my 2006 DL1000 and replacing both the stator, regulator/rectifier and upgrading the cables to the Eastern Beaver cables, and it still not charging I had the shop pull the stator cover and the following photo is what we found. Notice the magnets shifted together leaving a large gap on the right side of the photo and the bottom magnet (in the 6 o’clock position) has moved out toward the front of the assembly out of alignment with the other magnets by approximately 1/8 to 3/16 inch.
I have a new rotor assembly on order and will update this post if indeed this solves my electrical charging issue.
Edit: UPDATE- After replacing the rotor assembly the bike is back within the shop specs and charging normally now.
2012 Yamaha Super Tenere
Bahill is offline
post #15 of 31 Old 10-11-2011, 03:51 PM
TheGarMan's Avatar
Magnets sliding, separating from the rotor
Just to add to the list, I pulled my stator cover off and found that one magnet was loose, chipped and broken. The other magnets were all touching with no gap in between them. More of my sad story at: https://www.stromtrooper.com/dl-1000-...tml#post740120
-Gar
TheGarMan is offline
post #16 of 31 Old 10-11-2011, 04:04 PM
garandman's Avatar
I'll bet if you write a letter to the President of American Suzuki, you will get back a letter offering condolences and a $1,000 credit towards purchase of a new motorcycle.
garandman is offline
post #17 of 31 Old 10-17-2011, 04:19 PM
gryphon51's Avatar
Originally Posted by sarge View Post
Not germane to this discussion but to Suzuki in general. We have owned 4 Suzuki autos and in every instance the electrical system or parts thereof have failed. Cheap, crappily made controls or parts have precipitated the failures. The engines, transmission etc run forever. I still like Suzuki but wish that they would upgrade their electrical parts
oddly enough, I found this searching for info aboput the problem I am having.
for the record, the failure of my charging system yesterday was the first electrical problem I have had on my 2009 V Strom, which is well past the 90,000km's mark....
gryphon51 is offline
post #18 of 31 Old 10-17-2011, 08:36 PM
Living the Stereotype
Stromin'Nroman's Avatar
You can't be doing this to me.
I snorked Pepsi all over my keyboard.
OP, you have an ugly right big toe, best of luck to you with the bike.
Stromin'Nroman NC28729, USA
Stromin'Nroman is offline
post #19 of 31 Old 10-27-2011, 01:24 PM
TheGarMan's Avatar
New stator and rotor assembly installed...
I let the dealer install the new stator and rotor assembly to the tune of $900. That's the only time in 5 years I've spent any money on the Vstrom aside from oil, filters, tires and farkles.
-Gar
post #20 of 31 Old 02-08-2012, 04:52 PM
garikan41's Avatar
Send a message via MSN to garikan41
ı had had this problem onr years ago and then ı changed rotor about 300 $ my rotor two magnets was broken...yesterday my friends call me he has a klv 1000 his rotor magnets broken, ı gived my other magnets he sticked on rotor and now good charging.
just ı want to share
wherever ı my room[SIZE="6"][FONT="Impact"][/FONT][/SIZE]
garikan41 is offline
