High Beam Flasher and Headlight Kill Switch - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Feedback to Suzuki Only post information that you feel Suzuki would benefit from knowing. Not a "conversation" section
post #1 of 10 Old 06-10-2010, 08:55 AM Thread Starter
I was able to get an aftermarket Euro switch for my KLR 659 for $50 bucks. The headlight kill switch had 3 postions - run/running lights/and all off but brakes. If I ever had a starting problem I could shut of the headlights preseving battery juice that can be precious in flat backcountry.
The high beam flash to pass was a LIFE SAVER. The trigger switch was used often and saved me numerous times. Many high end bikes have this feature...Why cant my DL1000 ever have it?
Thats all. Thanks for not listening.
BTW thanks for the 6th gear light. It rocks!
WheelingWillie is offline
post #2 of 10 Old 06-10-2010, 10:27 AM
SCraig's Avatar
All of the V-Stroms I've ridden DO have a flash-to-pass switch
Scott Craig - Nashville, TN
SCraig is offline
post #3 of 10 Old 06-10-2010, 11:28 AM
Only the 2002 and 2003 models did not have the flash to pass switch. Some European Stroms are or were available with a headlight switch too. Eastern Beaver has a switch that can be used to turn off the headlights. http://www.easternbeaver.com/Main/Bi...html#lobeamcut
post #4 of 10 Old 07-30-2010, 04:56 AM Thread Starter
This makes it even worse. I was so close on my 03 yet still so far away. hey Greywolf you think an 04 switch would be compatable? Same harness?
post #5 of 10 Old 07-30-2010, 01:17 PM
It's possible. The additional wiring for the flash to pass switch is entirely inside the handlebar switch housing. The connectors are part of the main wiring harness and the handlebar switch, both of which have different part numbers for the two years so that's no help. See if your connector looks like the one for the left side extension in the picture. It is for a 2004 or later model. The colors won't be the same so ignore that.
post #6 of 10 Old 08-02-2010, 03:39 PM
Unless I'm missing something the flash to pass on my '08 Wee only works if the headlight is on low-beam. What I would like to see is what I think the OP was suggesting is that the switch actually switch between low/high no matter where the headlight switch is positioned.
Jeff
'08 Suzuki DL650
'01 Honda ST1100
MSGulfCoaST is offline
post #7 of 10 Old 08-02-2010, 04:21 PM
ozart's Avatar
I didn't read that from the OP, but maybe I'm having interpretation problems. What you're suggesting with the flash to pass switch would be a trick, but not impossible.
ozart is offline
post #8 of 10 Old 08-02-2010, 06:26 PM
The flash to pass switch turns on the high beam. If it is already on, there will be no difference.
post #9 of 10 Old 08-02-2010, 07:07 PM
ozart's Avatar
Right, although I think MSGulfCoast is talking about modifying the circuit where the flash to pass switch would also cut out the highs (when on) and switch to lows - again, maybe miss interpretation on my part.
ozart is offline
post #10 of 10 Old 08-06-2010, 11:15 PM
andreas's Avatar
I am thinking of replacing my left switch assembly for one from the 2010 Honda VFR1200F. Honda swapped the turn signal and hor switch. Horn is where the signal would be... etc..
FB MEMBER #133 - 2008 Wee
andreas is offline
