Drain Holes On Forks - Page 3 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Feedback to Suzuki Only post information that you feel Suzuki would benefit from knowing. Not a "conversation" section
 17Likes
post #21 of 26 Old 02-10-2019, 04:24 PM
WildDoktor's Avatar
Originally Posted by Rolex View Post
I always put a strip of green scourer pad (the thing the bride uses to scrub the pots and pans) between the dust seal and the oil seal...
Sounds interesting but I can't picture where you're doing this? Have a photo?
I'm about to do my forks, so it should be "interesting" to see how well the PO has maintained these forks. I've only had the bike for about 3k miles, and got it with 60k, so...yeah; we'll see!
2004 V-Strom 1000 (currently broken - parts received - repairs in progress - snag hit - repairs on pause - gofundme campaign started)
Two Brothers with P1 tips, PCIII USB, SuperBrace Fork Brace, K&N filters, ROX bar risers, Kappa top and side cases, MadStad, Givi tall windshield, Givi engine guards, Sargent Seat, 12 volt air compressor, 530 Conversion, 17/44, SpeedoDRD
WildDoktor is offline
post #22 of 26 Old 02-10-2019, 08:07 PM
Rolex's Avatar
I will assume you have the old 1000 and I will also assume they are like most bikes.
When you look at the top of the lower fork tube you will see a seal, that is only a dust seal, put a small screwdriver between the seal and the lower fork tube then flip the seal up and out of the lower tube & slide it up the upper tube.
Now look in the gap you have created and you will see the oil seal.
Cut a strip of scourer and put it in that gap, now push the dust seal back into place and you are done.
Motor7 and WildDoktor like this.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #23 of 26 Old 02-12-2019, 11:14 AM
chicago's Avatar
fork boots can help protect seals from dirt/dust/bugs and also offer protection to the tubes from small stones/dried bugs. One piece rubber type requires dismantling tubes or the neoprene/velcro type that wraps around. one trooper mentions he found oil was much cleaner using boots.
iamsmiling likes this.
14 tooth for me
chicago is online now
post #24 of 26 Old 02-12-2019, 10:57 PM Thread Starter
Juan_Banjovy's Avatar
Originally Posted by Yarz1 View Post
Having just done my first fork oil change on my Vee, I can say there's more to it than just draining the oil through 2 holes at the lowest points, like perhaps draining the engine oil. Oil remains in the damper until pumped out. You can't get that out by simply opening the hole at the bottom of each fork tube and letting it drip out. And if it so happened that the damper would actually drain that way, how are you going to pump the air out of the damper and get oil back into it by just using a drain hole for changing the fluid? Besides, to get your oil back in that you drained through the two bottom holes, you still have to remove the fork tube caps. So to me it seems that you've done 75% of what I just did by taking my tubes off and disassembling them.
Obviously the caps must be removed to pour in the fluid. I assumed everyone knew that.
Blue '07 DL650
Juan_Banjovy is offline
post #25 of 26 Old 02-14-2019, 11:52 AM
DonOhio45813's Avatar
Just curious, for those that want fork drain holes, why not grab your drill and tap set, and add 'em yourself.
DonOhio45813 is offline
post #26 of 26 Old 02-14-2019, 01:46 PM Thread Starter
I've seriously thought of doing that. I researched it & some have done that. Others say it weakens the fork & is risky, though I haven't heard of it actually causing a problem. Sort of like having to take the engine out & turn it upside down to change the oil. Some won't mind & will defend it but at least give us another option Suzuki. Even us 1 percenters. No harm done. It was done for decades for a reason. I guess Suzuki isn't the only one. Here's what Rider Magazine says: https://ridermagazine.com/2016/01/10...l-drain-plugs/
Blue '07 DL650
Shifted front forks? doetwa General V-Strom Discussion 8 07-19-2012 05:49 PM
Super Brace Installation Woes - Pumping Forks Didn't Work AmericasFirstFreedom Maintenance, Tech and Products. 11 01-02-2011 04:47 AM
Oil Drain Plug Rethreading causseur DL650 and DL650A - 2004 to 2011 23 02-15-2009 10:44 AM
OIl Drain Plug crush washer question basstodave V-Strom Service and Maintenance Questions and Discussions 3 04-08-2008 04:28 AM
