Threadlock ALL mounting bolts - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Feedback to Suzuki Only post information that you feel Suzuki would benefit from knowing. Not a "conversation" section
 2Likes
post #11 of 15 Old 07-30-2015, 04:33 AM
p38arover's Avatar
Don't forget the two bolts that hold the front headlight/fairing mount on the Wee (and probably the Vee) frame. Many have vibrated out.
Ron B. VK2OTC
2007 Yamaha XJR1300
RIP Bucko
1979-2008 - Riding on forever
p38arover is online now
post #12 of 15 Old 07-30-2015, 07:20 AM
VSrider's Avatar
Also, don't over do it using loctite on steel bolts going in to aluminum threads. Had to replace the entire throttle body on my Ford truck because of it.
VSrider is offline
post #13 of 15 Old 07-30-2015, 09:48 AM
"Had to replace the entire throttle body on my Ford truck because of it."
See what I mean!
notacop is online now
post #14 of 15 Old 07-30-2015, 01:04 PM
raYzerman's Avatar
I'm not a chemist, but I'll try to clarify my post based on my experience from a lot of wrenching bikes. The liquid types do seem to have a carrier solvent that will dry off (albeit slowly), and the applicator tip will plug up if you leave the lid off. You hardly ever need to use more than one drop, which will flash off a lot faster than 3 drops. In the OEM auto biz we had many fasteners pre-coated with Loctite patches, which were yellow, blue, orange, or red. Likely a different formula than what we buy off the shelf, but they had dried similar to a dried soap. Anyway, I'm mostly referring to the blue liquid type I think most of us use.
IMHO you have to evaluate the need for Loctite for each joint, e.g., anywhere there is a rubber grommet/washer, which perhaps has a shoulder on the screw that bottoms out, you likely don't have to use it unless it is chronically vibrating loose. Then, use sparingly so no excess gets on fairing/fender plastics (which could be ABS, PPE) as it will eat those. I've never used Loctite on any plastic screw or threaded nut.
I do use it on critical or safety fasteners like caliper bolts, pinch bolts, brake rotor bolts, etc., and treat it like a lubricated fastener when torquing. A bi-metal galvanic reaction will occur with aluminum to varying degrees depending if it is steel, stainless, galvanized, copper. If you remove/replace the fastener often enough, not so bad. If it's an engine mount bolt that you rarely if ever remove, then use some anti-seize on the threads. Galvanized into aluminum is the worst and reacts in the shortest time. Always use an impact driver to remove stubborn ones of any type.
So, use sparingly, and you'll have to decide in individual fastening cases to use thread locker, anti-seize or nothing.
raYzerman is offline
post #15 of 15 Old 07-31-2015, 08:25 PM
Kurgan's Avatar
Aside from those particular fasteners the factory states should have a drop of Loctite, I don't use the stuff. I just go over the bike front to back, top to bottom when I bring it home and make sure the smaller fasteners are snugged down (bodywork, engine case covers, etc) and the rest I check with a torque wrench. No issues with things falling off or coming apart in the 4 years since I purchased it.
Jim
Kurgan is offline
