Premature Stator Failure - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Feedback to Suzuki Only post information that you feel Suzuki would benefit from knowing. Not a "conversation" section
 7Likes
post #1 of 17 Old 06-14-2015, 06:08 PM Thread Starter
I recently had a total failure of the charging system caused by a burned out stator winding. The bike ,a 2013 650 only had 20,000 km on the clock and this type of failure needs to be addressed by Suzuki.
I have reviewed this forum and this is not an isolated failure, others have had the same failure with less kilometers on their machines.
Step up to the plate Suzuki and do the right thing, admit the problem and reimburse the expenses this failure has caused.
Bairn123 is offline
post #2 of 17 Old 06-18-2015, 09:34 PM
bwringer's Avatar
Undersized and unprotected electrical connectors and wiring are a Suzuki problem that goes back at least 40 to 50 years. The world is absolutely littered with the charred remains of Suzuki stators and regulators.
They didn't give a crap then, they've never once given a crap, and I doubt they're going to start giving a crap now.
If anyone at Suzuki is listening: please fire the idiot in charge of the electrics. Go ahead and spend another five bucks per bike on decent electrical connectors so we can ride in the rain sometimes.
Seriously, it's hurting your reputation. The bikes are mostly pretty great otherwise, but they'd be even better if we didn't have to drop several hundred bucks on stators, regulators, and batteries quite so often. And personally, I'm sort of sick of spending hours with heat shrink, wire, connectors, and crimpers patching around your crap so I can ride.
You could at least knock a few bucks off stator prices...
And while you're at it, fire the anorexic ballerinas in charge of spring rates...
pvwheeler, CollingsBob and amaniji like this.
bwringer is offline
post #3 of 17 Old 06-23-2015, 05:35 PM Thread Starter
Right on Bwringer. More people need to complain to Suzuki. My bike is up for sale and it is the first and last Suzuki I will ever own.
Bairn123 is offline
post #4 of 17 Old 06-23-2015, 05:44 PM
If you think other makes do better, Yamaha and Suzuki are rated one-two in reliability in the last survey I saw. Nobody is perfect.
Big B, flgolfer29 and DaveinNC like this.
post #5 of 17 Old 06-25-2015, 06:38 PM Thread Starter
Yes of course any machine can fail as you mentioned when the Stator on my bike self destructed several weeks ago.
The thing is it never occurred on any bike I have owned in the last 40 years.
First and last Suzuki I will ever own.
Bairn123 is offline
post #6 of 17 Old 06-25-2015, 07:23 PM
Plenty of charging systems on cars and bikes of different makes have failed in the past. That none were yours is more of a statement of luck than quality.
post #7 of 17 Old 06-25-2015, 07:31 PM
emc2's Avatar
When the Kawasaki 300 first came out a problem surfaced with the ECU. Basically, some bikes would stall unexpectedly. After much talk about the issue on the 300 forum (and no action on the part of Kawasaki) folks started filing their complaints with the NHSTA at
https://www-odi.nhtsa.dot.gov/ivoq/
Shortly thereafter, Kawasaki decided to issue a recall to replace the ECUs.
I don't really see the difference between the Kawasaki situation and the stator problem. In both cases the end result (unless you have installed a volt meter) is an unexpected stall.
I'm not trying to start a war with Suzuki here - I think they're a fine company - I'm just sayin...
emc2 is offline
post #8 of 17 Old 06-26-2015, 03:14 AM
I have a K6 Vee and it has just, today, clocked up 60,000 klms so it doesn't have a hard life. No commuting, no dirt, regular oil and filter changes, regular maintenance. My stator failed at around the 35K mark and I replaced stator, battery and RR (with a Mofset unit) at the same time. The fuel pump failed the following week. An expensive couple of days but the Mofset RR is powering on and gives me every confidence while I can't get away from a "cross fingers and hope" feeling with the stator.
Don.
Maroon K6 Vee.
Donunder is offline
post #9 of 17 Old 09-26-2015, 06:52 AM
AlH
Suzuki does seem to not listen- I also have a DR650- the screws that hold the neutral sending unit back out and can cause total destruction of the motor-
theses screws have been left loose at the factory for at least 10 years- yet they do nothing about it.
The sad part is it would cost NOTHING for them to tighten the damn screws and maybe even splurge and put a penny's worth of thread locker on them.
BTW I have my Vee spare stator in hand already- that pretty much guarantees mine will never fail
2004 DL1000
1998 XR400
2000 KDX200
2013 DR650
AlH is offline
post #10 of 17 Old 09-26-2015, 01:29 PM
V-Tom's Avatar
I have a theory that Stator/Charging system failure is more likely in bikes that are ridden gently. It seems most of the failures I recall hearing of are people that seem to ride gently and not use the top half of the rev range that much. I wonder if a poll on that subject might support that or blow away that theory.
..Tom
2015 DL1000 New July 2015 175,000+ km, 108,500+ miles.
SMIDSY detailed report.
V-Tom is offline
