Valve Adjustment Help Needed - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
  • 1 Post By HokiesRWee
  • 1 Post By Jhat
  • 1 Post By blaustrom
  • 1 Post By Jhat
post #1 of 7 Old 11-08-2019, 12:53 PM Thread Starter
I am having problems with the valve adjustments. I cannot get the chain tensioner to release.
I am following these instructions:
Suzuki V-Strom DL650 Valve Check and Adjustment
I have taken all of the tension out of the tensioner by backing the bolt all of the way. My problem is that i cannot get the little tab to release to release the tension on the cam chain. I have tried pushing on the tab with a screwdriver but nothing budges. From the videos i have watched, this looks like it should be easy. What am I doing wrong?
Thanks
2017 V-Strom 650
2012 DRZ 400
Jhat is offline
post #2 of 7 Old 11-08-2019, 02:18 PM
I'm not an expert, but I've done this work twice.
On my 2012 Wee, at least, I recall having to completely remove the tensioning bolt and spring from the engine (they come out together - not terribly difficult to get back in place).
Even then I recall having a bit of trouble getting the chain loose enough to remove a cam, but I eventually got it. I did this work about 10 months ago.
Hope this helps, somehow. Good luck.
Spec likes this.
2012 Wee2 Adventure. Black. Bought at 26K miles. Now 46K+. Love it!
HokiesRWee is offline
post #3 of 7 Old 11-08-2019, 07:07 PM Thread Starter
I got the adjuster to release. It just needed a little persuasion on the handle of the screwdriver to get it to release. I almost resorted to taking out the entire cam chain adjuster out of frustration. There is not a lot of extra room when it is released but there is just enough room to move the cam out of the way to remove the buckets.
HokiesRWee likes this.
2017 V-Strom 650
2012 DRZ 400
Jhat is offline
post #4 of 7 Old 11-08-2019, 07:12 PM
blaustrom's Avatar
Hope you zip tied the chain to the cam sprocket. That way you don't have to fuss with counting chain links and worrying if they are in the correct position.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #5 of 7 Old 11-08-2019, 07:13 PM Thread Starter
I used a bungee cord so nothing can slip. The zip tie idea is also a good one.
2017 V-Strom 650
2012 DRZ 400
Jhat is offline
post #6 of 7 Old 11-08-2019, 10:49 PM
Out of curiosity, how many miles since last inspection/adjustment? And what if any adjustments were required? Thanks.
Cheers
RLBranson
RLBranson is offline
post #7 of 7 Old 11-08-2019, 11:36 PM Thread Starter
If the question is for me, this is the first valve check at 15,000 miles. All four exhaust valves are at the minimum of 2mm so I will be changing the shims. The intake valves are all well within spec so no changes there.
thecrumb likes this.
2017 V-Strom 650
2012 DRZ 400
Jhat is offline
