unstable engine at steady 2200-2500 RPM - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 15Likes
post #1 of 24 Old 09-05-2019, 04:20 AM Thread Starter
If I drive with constant speed in 1st, 2nd or 3rd gear and around 2200-2500 RPMs, engine seems "erratic". Don't know exactly how say it, but in Denmark we call it "setting out". It is like the engine is not firing the same was on all ignitions even though load and speed is exactly the same.
Accellerating is just fine.
s this normal on a wee?
DK650A from 2017, 1500 KM
Regards, Lars.
bonne is offline
post #2 of 24 Old 09-05-2019, 09:20 AM
K9 Wee's Avatar
Hi Lars -
Could this be slack in the throttle cables? The Wee has a very touchy throttle and the slightest input will make it seem "jerky" in response. This is amplified with slack in cables. Just a thought from what you described.
______________________
2009 Orange DL650
SW Motech Rally Crashbars, Skidplate & Centerstand
Givi e22L Sidecases
Shad 33L Topcase
Wolfman 40L Waterproof Duffel
Givi Tanklock 20L Tankbag
Techiwik Long Underwear
1978 Honda CB550K-Sold
K9 Wee is offline
post #3 of 24 Old 09-05-2019, 01:24 PM
Spec's Avatar
Regards, Lars.
The bike runs lean at smaller throttle openings makes the response touchy.
I would hazard to guess that you're lugging the motor in third at those RPMs.
The motor is much happier 4k and above. The only time I'm below 3k is in first going to second!
chicago and RestoRider2017 like this.
Spec is offline
post #4 of 24 Old 09-05-2019, 06:45 PM
Stalky Tracker's Avatar
I'm with Spec. Mine is twitchy at low rpms too. Idles fine but try to run down the road at 2,000 rpm and twitchy/surgey/erratic. Been that way since new, cruises 3000-4000+ just fine.
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #5 of 24 Old 09-06-2019, 01:00 AM
blaustrom's Avatar
Check the TPS setting. Quite a few are not set correctly from the factory. Make sure that the 650 specification is the same as the 1000 in this thread:
https://www.stromtrooper.com/dl1000a...tle-off-3.html
Cryoman likes this.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #6 of 24 Old 09-13-2019, 08:04 AM Thread Starter
You think so? As long as you do not put engine load on the bike at those RPM's, I think it is ok. It does not sound as it is struggeling. If I am accelerating, I would certainly downshift.
Do you run it in 4K even if no load on engine?
Regards, Lars.
bonne is offline
post #7 of 24 Old 09-13-2019, 11:10 AM
Spec's Avatar
Regards, Lars.
I don't know why you would want to be in third at 2.5k RPM.
OK you shift down if you want to accelerate but why not be in second at 1k RPM higher? The motor will be much smoother and more responsive.
Big B, Webfors and RestoRider2017 like this.
Spec is offline
post #8 of 24 Old 09-13-2019, 11:15 AM
It should feel erratic around 2250 - 2500 RPMs, the motor isn't designed to operate in that range. The fuel is quite lean in that rpm range. I find the minimum engine speed for the Vstrom/SV650 is 3500 RPMs.
Webfors likes this.
gorbulan is offline
post #9 of 24 Old 09-13-2019, 11:21 AM
DonOhio45813's Avatar
A TB sync may help too, but lugging it in 3rd is begging for the herky-jerkies!
DonOhio45813 is offline
post #10 of 24 Old 09-13-2019, 06:57 PM Thread Starter
Yes, of coarse it will be more responsive in that RPM. When cruising at low speed I do not need responsiveness. The higher RPM will make more noise, use more gas and sound more aggressive. That is not what I need.
I want to drive in the correct RPMs and of coarse I do not want to overload the engine. Would you say what I am doing is wrong? I just consulted the owners manual. It says "shift to 3rd at speed 34 km/t" which I recall is not far from 2500 RPMs - I will check the next time I drive 34 km/t.
Regards, Lars.
bonne is offline
