What's the location of accessories plug? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
post #1 of 12 Old 08-24-2019, 03:23 PM Thread Starter
Also is there 2 of them like on previous model?
Rick123 is online now
post #2 of 12 Old 08-24-2019, 03:40 PM
I have been looking for one of those also. I think I am going to have to remove some stuff to get near it.
RLBranson is offline
post #3 of 12 Old 08-24-2019, 10:02 PM
Brockie's Avatar
There is only one "heated grips/accessory wiring" plug. This is the 2012-16 plug, but the same as yours. https://www.stromtrooper.com/dl650a-...-location.html
Also look here for a plug to mate it to so that you never have to go down into there again. Same as the horn plug. https://www.stromtrooper.com/dl650a-...male-plug.html
Brockie is offline
post #4 of 12 Old 08-24-2019, 10:46 PM
Hogges's Avatar
Brockie, important to note, the 2017 and up plug looks different and the linked Eastern Beaver cable is not going to work. The correct connector is called “MT sealed Sumitomo connector 6187-2171”. It looks more rounded. Eastern Beaver has it I think. I ordered the raw plugs on Aliexpress as I already owned the crimp tool to make my own cables.
The single accessory plug is behind the radiator up high taped to something. I was able to reach it and remove the tape while sitting on the floor on the left side of the bike, without removing any bike parts.
Brockie likes this.
Hogges is offline
post #5 of 12 Old 08-24-2019, 11:27 PM Thread Starter
Thanks guys. Now at least I know there is only one (and not like 2012-16 2 of them) and is located in the same place as on my 2015.
post #6 of 12 Old 08-24-2019, 11:47 PM
V-Tom's Avatar
If the latest DL650 has a power plug (cigarette lighter socket) on the dash like the 2014+ dl1000 it basically is a switched 12v source. The fuse is quite low but it should be fine for using as a trigger for a fuse box.
..Tom
My Opinion:
Vee or V= DL1000 before 2014
Vee3 or V3 = DL1050 2020 to?
My Stroms:
SMIDSY detailed report.
V-Tom is offline
post #7 of 12 Old 08-25-2019, 11:53 PM
Rolex's Avatar
The horn is another easy place to find switched power.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #8 of 12 Old 08-26-2019, 10:09 AM
there are 3 asfik new style plugs available. One on the left side of the tank, near the horn, easy access, I used that one for gps power.
Another is under the dash/clock and third one somewhere under the seat on the side.
offnote is offline
post #9 of 12 Old 09-08-2019, 11:12 AM
I'm not sure of the difference between an "accessory plug" and a "power plug" to install heated grips. But my 2018 V-strom 650XT has this easily reached plug right underneath the front beak. If you're facing the bike, it's under the right side, and appears to be plugged into nothing but a plug/holder attached to the backside of the beak. Does anybody know if that is for the heated grips? It doesn't seem to fit the "horn lead" that others have said to use. BTW, I now have a couple of those if anybody wants one. This one looks more like it needs:
Sumitomo MT090-2B 2pin sealed Motorcycle Connector M(6187-2171) - F(6180-2181)
tjosephtoo is offline
post #10 of 12 Old 09-08-2019, 08:21 PM
That connector you found under the beak is the ambient air temperature sensor. The heated grips connector is near the horn behind the radiator on the left side of the bike. It is white but it is wrapped in electrical tape so you may look past it at first. You do not have to remove the radiator or tank to get to it but removing the left fairing makes it easier to find.
Big B likes this.
2018 V-Strom 650 XT - Champion Yellow
Rustlr63 is offline
