Low oil?? - Page 3 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 29Likes
post #21 of 47 Old 08-20-2019, 10:45 PM
brock29609's Avatar
Originally Posted by V-Tom View Post
I just did a quick Google check and it looks like the difference in Volume between 15°c and 100°c is about 6.5%, at least for Fuel oil which I suspect is similar...
My only real-world experience with this was with my recently-owned BMW R1200R. When the oil was cold it would cover about 60% of the sight glass. When it was up to temp it would rise all the way to the top. Of course that bike held more oil volume. Haven't experimented with this on the V-Strom.
V-Tom likes this.
brock29609 is offline
post #22 of 47 Old 08-21-2019, 04:50 PM
V-Tom's Avatar
If I get a chance this weekend I am going to look at oil level cold and after idling for three minutes and see how it differs (if at all.) I wonder if on BMW's horizontally opposed engine it is harder for oil to drain back and if they use an internal dry sump system.
..Tom
My Opinion:
Vee or V= DL1000 before 2014
Vee3 or V3 = DL1050 2020 to?
My Stroms:
SMIDSY detailed report.
V-Tom is offline
post #23 of 47 Old 08-22-2019, 07:38 PM
Mike Ford's Avatar
The Honda CB125 only hold 800ml of oil. Hope your bike engine is ok.
Mike Ford is offline
post #24 of 47 Old 08-23-2019, 09:07 AM
My BMW's never seemed to show less when the oil was cold.
Older BMWs needed to be allowed to rest on the side stand for a few minutes, then put on center stand. This allowed the oil cooler to drain into the sump. They are not dry sump engines. Once on the center stand, a glance at the oil window would give an accurate gauge of oil level.
Many owners would add a bit as it seemed low, but then it would be over full. This was due to not allowing the oil cooler to drain back into the sump. Once you owned the bike a while, you could go directly to the center stand and although it might be a bit below halfway on the window, you knew it was going to be spot on allowing for the oil cooler volume.
Being in the clutch basket business for V STroms, I often get asked about what brand oil to use. My response is "enough"! In my opinion, if you can see the oil in the sight glass when the bike is level, it is probably safe to ride. Over filling isn't good, as it can put more pressure on seals and force oil mist into the airbox. Not rocket science. Get it close to right and it is good to go. Just check it often.....
Big B and V-Tom like this.
realshelby is offline
post #25 of 47 Old 08-23-2019, 10:36 AM
chicago's Avatar
I always check the oil when it's cold because I check before a ride.
14 tooth for me
chicago is offline
post #26 of 47 Old 08-28-2019, 01:43 PM
Originally Posted by Boriqua View Post
Your not allowed to mention that brand you use?! Jeez a little strict there Tom. I don't care who uses what. I only mentioned the brand as it relates to cost of an oil change when you change 4 qts.
Meh .. its your house your rules but over moderation sucks on all boards.
Meh....you're the new guy here, and no this isn't a new rule or "over moderation".
post #27 of 47 Old 08-28-2019, 02:27 PM
brock29609's Avatar
Originally Posted by WingVetteStrom View Post
Page 7-20. 2018 Suzuki V-Strom: Check the oil with the bike on a level surface ON THE SIDESTAND.
Run at idle for 3 minutes then let it sit for 3 minutes before checking.
I don't know where you guys are getting this "check the oil with the bike upright" stuff.
You're mistaken. Read your manual again. I posted a screen shot from the manual earlier in this thread which says to hold the bike "vertically" when checking the level.
Sounds like your bike is waaaaay overfilled. I'd quickly fix that.
All our bikes lean at different angles on their side stands due to different tire types, tire wear, suspension preload, ride height mods, etc. Because of this they wouldn't ask people to read a side stand level.
V-Tom likes this.
post #28 of 47 Old 08-28-2019, 03:15 PM
Sounds kinda dangerous checking the window hunched over while the bike is balanced level. Could get away from you. Does the centre stand get it close to accurate? I think I will make note of the position on the window at the next oil change after putting in the specified amount while on he centre stand
Bob S 2017 Vstrom 650 Base model (White)
2018 Yamaha WR250R
1984 Honda VF 500f Maybe more coming up from the lower list
Previous loves:
2017 Yamaha YZ250X
1982 Yamaha 650 Seca 1978 Honda CB550
1974 Suzuki GT380 1977 Yamaha RD400
1973 Can Am MX1 125 (Bought while Mom was out of town)
Nicad is offline
post #29 of 47 Old 08-28-2019, 03:30 PM
oldjeep's Avatar
Should be, the problem is that the centerstand is an option so they can't say - check it on the centerstand
Chuck P
2004 DL1000
2003 FZ1
www.oldjeep.com
oldjeep is offline
post #30 of 47 Old 08-28-2019, 03:59 PM
brock29609's Avatar
Yes. Plenty accurate
Of you don't have a center stand you really should own a paddock stand to maintain the bike with. They're not expensive.
No hunching required. Not hard to hold the bike upright and look down at the site glass while standing. Or, borrow a buddy.
