Low oil?? - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 29Likes
post #11 of 47 Old 08-20-2019, 04:14 PM
V-Tom's Avatar
Originally Posted by brock29609 View Post
Just keep in mind how to accurately check the oil level. The bike must be warm, then let it sit for 10ish minutes so it can all drain down to bottom, then look at the sight glass while it's upright.
No, the oil does not need to be warm. It doesn't hurt but there is no reason to have warm oil to check the level.
Changing the oil: yes Warm oil is best.
Checking the oil: Makes no matter.
..Tom
ERockJL likes this.
My Opinion:
Vee or V= DL1000 before 2014
Vee3 or V3 = DL1050 2020 to?
My Stroms:
SMIDSY detailed report.
V-Tom is offline
post #12 of 47 Old 08-20-2019, 04:36 PM
..Tom
Motor oil seems to change in volume quite a bit between room temperature and operating temperature, and the oil level with it. I'm not sure if it's intended to be checked cold or hot. On my BMW it's meant to be checked with the engine hot, apparently.
V-Strom Ry 2 is offline
post #13 of 47 Old 08-20-2019, 04:45 PM
Boriqua's Avatar
Mod comment:
Please don't turn this into an oil thread. If you want to talk about brands of oil etc please do it in the oil thread.
..Tom
Your not allowed to mention that brand you use?! Jeez a little strict there Tom. I don't care who uses what. I only mentioned the brand as it relates to cost of an oil change when you change 4 qts.
Meh .. its your house your rules but over moderation sucks on all boards.
Alex
2019 V-Strom 650XT
1982 16v Suzuki GS 750E
Boriqua is offline
post #14 of 47 Old 08-20-2019, 05:05 PM
V-Tom's Avatar
Please don't throw over moderation at me. This board has very little moderation as it largely isn't needed. I don't make the rules but support and help enforce them. Your comment about your favourite oil isn't relevant and not worth turning this into an oil thread. (BTW other mods here generally delete threads that turn into an oil thread. I usually merge the thread into the oil thread.)
When one person starts talking about their favourite brand of oil the next thing everyone else does. It isn't needed or relevant in this thread but feel free to talk about your favourite oil in the Oil thread.
Here is the link to help you along:
https://www.stromtrooper.com/general...il-thread.html
..Tom
Big B, SKM348 and RLBranson like this.
My Opinion:
My Stroms:
V-Tom is offline
post #15 of 47 Old 08-20-2019, 06:26 PM
brock29609's Avatar
The level marks on the site glass are for warm oil. Of course you can view the level when it's cool, but warmer oil expands and will show higher in the glass. You're in danger of overfilling of you fill cold oil to the top mark.
brock29609 is offline
post #16 of 47 Old 08-20-2019, 06:28 PM
brock29609's Avatar
Every owner's manual I've read (both cars and bikes) says check the level when it's hot.
Looks like Suzuki wants it warmed for 3 minutes...
post #17 of 47 Old 08-20-2019, 07:03 PM
V-Tom's Avatar
I just did a quick Google check and it looks like the difference in Volume between 15c and 100c is about 6.5%, at least for Fuel oil which I suspect is similar. (15c is 59f and 100c is 212f and is typical oil temperature for a running engine.)
https://www.engineeringtoolbox.com/f...50-d_1942.html
..Tom
V-Strom Ry 2 likes this.
My Opinion:
My Stroms:
V-Tom is offline
post #18 of 47 Old 08-20-2019, 07:06 PM
V-Tom's Avatar
Thanks for pointing that out! I stand corrected! Although in 3 minutes oil would barely get warmed. I have a feeling this is introducing greater error in the oil level reading and is bad advice just like the torque for rear axle.
(Thankfully my Stroms haven't run out of oil over the last 535,000 km / 332,000 miles of riding. )
..Tom
Cryoman likes this.
My Opinion:
My Stroms:
V-Tom is offline
post #19 of 47 Old 08-20-2019, 08:59 PM
locoblanco's Avatar
Three minutes may not get the oil to maximum temperature, but should get hot enough expand some. Thats probably why the manual says "between the L and F mark". Allow for a bit more expansion if its going to happen.
In any case, the 650 takes 2.7 liters w/filter, so I just put that much in and go for it. (Yes, I have double checked in the sight glass, and that comes to exactly on the F mark.)
But to the point of the original post, something was done wrong at the shop. I would request a complete check, including compression test and oil pressure test, at the shops expense.
Boriqua likes this.
locoblanco is offline
post #20 of 47 Old 08-20-2019, 10:27 PM
Yeah, sorry to hear this. This experience needs to become part of the dealer's service records of your bike in case there is a problem later. Suzuki needs to hear about it, too. The service manual shows the range of normal oil pressure at 29-87 psi @ 3000RPM and 140 degrees F. That's a big range, but within legendary Smokey Yunick's theoretical 10psi at idle + 10psi for each 1000RPM. There's a good chance you're OK. It does need to be drained and accurately measured to see how much they (obviously) left out. The difference between the quantity for oil change (2.5 qts) and oil and filter change (2.7 qts) is less than 10%, probably not enough to trigger the pressure light unless the bike is leaned over. If my logic is wrong here please correct me. Maybe RealShelby will jump in here.
So, I'd measure the amount of oil it takes to bring the level to the normal level and document it on camera. Then I'd raise all unholy hell, but not worry too much just yet. I'm sorry to hear another dealer has joined the suspect list, at the expense of a rider who was just trying to do the right thing. Best, DD
Dubldee17 is offline
