oil filter wrench size - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
post #1 of 18 Old 08-14-2019, 08:25 PM Thread Starter
Can someone please confirm what size oil filter wrench the 2017 650 takes? I bought a 14 flute 68mm, as I was sure that was what I had seen online, but it didn't fit. It was a Performance Tool 14 flute 68mm from Amazon.
Did I misread the size required somewhere?
Mark Robson is offline
post #2 of 18 Old 08-14-2019, 09:40 PM
scab's Avatar
I don't know what the size is supposed to be. I've got every one of them. I never have good luck with any fitting well enough to remove the filter efficiently. I use these instead: https://www.harborfreight.com/oil-fi...ers-61477.html
If you're not living on the edge, you're taking up too much space.
scab is offline
post #3 of 18 Old 08-14-2019, 09:51 PM
Bazooka Joe's Avatar
How about a large Channellock Tongue Groove Pliers?
notacop likes this.
18 1000 XT yellow. Bunch of goodies installed.
2015 Yamaha WR250F- Street plated woods bike
Previous rides- about 25 different bikes, mostly dirtbikes.
Bazooka Joe is offline
post #4 of 18 Old 08-14-2019, 10:45 PM
Bazooka's got it. Big gomby water pump pliers form Harbor Freight.
There are certain universal tools that belong in everyone's tool kit.
i recently had to use my biggest pliers to open a jar of Artichoke hearts. My old hands don't have the grip required.
post #5 of 18 Old 08-14-2019, 11:42 PM
Brockie's Avatar
After trying a few over the years I have settled on either of these:
https://www.aliexpress.com/item/3289...chweb201603_55
https://www.aliexpress.com/item/32960662623.html
Both are positive no slip removal and I install by hand.
Brockie is online now
post #6 of 18 Old 08-15-2019, 01:40 AM
Why not put it on less tight so it can be removed without needing a tool? Seems to work for me...
I'm hoping the above still applies as the last filter I installed was a Hiflo with the o-ring stile gasket. I haven't used a Hiflo before so perhaps I'm going to be eating my own words...
gdrew is offline
post #7 of 18 Old 08-15-2019, 02:02 AM
I use a strap wrench with sandpaper under the strap. sounds like a lot of effort I know but it does make easy work of filters.
Broken strips from power files are ideal FWIW.
PeteW is offline
post #8 of 18 Old 08-15-2019, 08:52 AM
Suzuki sells the wrench. Harbor Freight set kind of wedges/jams. The OEM takes a pretty good twist due the different seal. I like the K&N filters for the little nut welded on. I do think you can always trust OEM filters as the very highest quality. Others hard to say.
kfh000
kfh000 is offline
post #9 of 18 Old 08-15-2019, 09:01 AM
Brockie, I have one of those leverage strap wrenches with a length of chain as the gripping surface.
You can really talk to a difficult filter with that! "Get loose or I will crush you to death!"
post #10 of 18 Old 08-15-2019, 09:30 AM
unscrew it with pliers or screwdriver then put new one using your hands only, that way you can undo it later same way.
Otherwise get some adjustable wrench.
offnote is offline
