intermittant problem 650 - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 7Likes
post #11 of 22 Old 08-03-2019, 11:01 PM
Spec's Avatar
Originally Posted by dancerdave View Post
Bikes a 2017 650 which I've had for a month, 800 miles. Problem is bike cuts out sometimes when I am standing on the pegs. Anything less than 40mph and 3000rpm , screen is totally blank with no warning lights BUT when I sit down again it automatically starts and rides normally. Battery terminals good and it only happens when I'm standing. Was at the dealer today and they couldn't see anything wrong and of course the bike behaved itself there. Anyone here had anything similar or have any ideas?
ps I'm not activating the side stand switch when I stand up
Do you keep a finger or 2 on the clutch lever all the time? Clutch switch maybe?
Yea I know weird idea huh.
Spec is offline
post #12 of 22 Old 08-04-2019, 02:03 AM
Rolex's Avatar
Sound like a bad power connection for sure so a bad plug or connection on the ignition system but why when standing only ?
I don't know what happens if the tilt switch is activated ? does it act like the ignition system is shut down and the dash goes blank ?
Are you 100% sure the kill switch is not being moved when standing ?
You say your battery connections are good, did you also check the earth where it bolts to the motor and the power cable where it bolts to the starter solenoid ?
dancerdave likes this.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is online now
post #13 of 22 Old 08-04-2019, 02:52 PM
RestoRider2017's Avatar
Location: Apopka Florida NW of Orlando near a twist in the road and a hill on the horizon...
This is a crazy one dancer dave hope you get it sorted out soon. Please let us know what you find- finally fixes it.
2017 DL 650 , Shad 23 bags, Givi crash bars, 32 watt LED aux lights , Goldwing pegs, Metalic silver front fender, Lazer cut aluminum Chain guard, Madstad 20" windshield
light smoke tint , Blu/blk Driven Racing Billet bar ends, Dbl Take adventure mirrors , Gel seat cover, Twin tool tubes, Givi 30L top case, Suzuki Engine cowl, 45 years in the
saddle and counting, Yoshimura 3/4 exhaust system simmering on low in the money oven.
AMA member, RestoRides MotorSports CEO
Our dog Trixie 7 year old Chihuahua / Min Pin mix Shelter Rescued Smartest dog we have ever owned. She's great and does lots of tricks.
RestoRider2017 is offline
post #14 of 22 Old 08-04-2019, 04:06 PM
MontanaGuy's Avatar
Another wild idea, but close to my battery is the tip over switch/box. Could it be that it is shifting position and killing the bike. It should have an up arrow on it to indicate the "on" position. My ECU is a bit harder to reach unless yours has been moved.
Current Motorcycles
2007 Wee
2010 BMW S1000RR
2001 Suzuki SV650S
2005 Vee R.I.P.
MontanaGuy is offline
post #15 of 22 Old 08-07-2019, 08:47 AM Thread Starter
dancerdave's Avatar
Booked in to the dealers tomorrow to get it plugged in as I can't see any bad connections/earths. Hope they find something
dancerdave is offline
post #16 of 22 Old 08-12-2019, 01:12 AM
Have you found a solution to the problem? DD
Dubldee17 is offline
post #17 of 22 Old 08-12-2019, 07:08 PM Thread Starter
dancerdave's Avatar
Took it to the dealers who plugged it into the computer - no faults. Checked the trip switch - fine. Checked the side stand switch - working. Checked the wiring and couldnt see anything wrong. He then took it for a test ride and ............ bike behaved perfectly!
I was adamant that the bike had a problem and asked what happened next so it was a process of elimination and he would bypass the sidestand switch first and told me to ride the bike for a couple of days.
The problem has not SO FAR reoccurred so either its a faulty switch or he has moved the wiring about and there is no short now. I'm going to ride it for another week to make sure.
You have self doubt when these things happen but if I had activated the sidestand switch when standing up yes it would have cut out but there would have been lights on the dash and on my bike it was blank so fingers crossed we have identified the problem.
Brockie and RestoRider2017 like this.
post #18 of 22 Old 08-12-2019, 10:16 PM
Brockie's Avatar
Great progress. Yes, you need to be sure an issue is resolved. If the fault fails to re-surface have a buddy observe you as you sit on your bike in your normal riding position.
Brockie is offline
post #19 of 22 Old 08-12-2019, 10:20 PM
Rolex's Avatar
I'm not sure with your bike you could check but this is what happens if it is the stand switch on a 2014 1000.
If the stand switch is activated while in gear you will see this.
Where the gear position is indicated the number will be replaced with a dash (-), the temperature gauge will fill to the top and you will get a check showing up on the dashboard.
The only problem is that it is not instant it will take a second or two to happen.
The stand switch should never leave your dashboard blank.
I recommend every trouper get to know these things about their bikes it could come in handy one day.
2014 V2, Snoopy
Rolex is online now
post #20 of 22 Old 08-17-2019, 10:09 AM
DancerDave : How is everything going with the bike now ? If the issues have stopped then the Side stand switch
is the culprit. Could be the body of the switch is fractured or an internal intermittant connection. In any case it should
be replaced with a new one to (hopefully) restore normal operation.
