chain slack - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By K9 Wee
post #1 of 4 Old 07-28-2019, 09:55 AM Thread Starter
chain slack
looks like on v-strom chain slack is on tight side as per manual. On most of my bikes I had more then 3cm.
Is that what are you usually setting? I have now around 3.5 cm and planning to leave like that.
offnote is online now
post #2 of 4 Old 07-28-2019, 10:06 AM
I don't know cm's from bm's. If you use your foot to lift the chain and it lifts comfortably and doesn't hit the swing arm, it's probably good. Better loose than tight.
Actually on the swing arm there is a decal specifying the required slack, unless someone was brilliant enough to remove it because the information offended them.
post #3 of 4 Old 07-28-2019, 10:24 AM
K9 Wee's Avatar
Yes, the recommended slack is on the tight side. 3.5 cm is roughly 1 3/4" which is better than the factory spec of 1.5" on side stand. Run a little loose, lubricate a lot, clean out front sprocket area regularly and the chain will last a long time. See V-tom's numbers for chain life for reference. Am at 18k miles on chain and sprockets now, looks like they'll go 25k or more without issue.
offnote likes this.
______________________
2009 Orange DL650
SW Motech Rally Crashbars, Skidplate & Centerstand
Givi e22L Sidecases
Shad 33L Topcase
Wolfman 40L Waterproof Duffel
Givi Tanklock 20L Tankbag
Techiwik Long Underwear
1978 Honda CB550K-Sold
K9 Wee is offline
post #4 of 4 Old 07-28-2019, 03:26 PM
I set mine at 25 to 30 and adjust when it hits 40.
I have only had to adjust it three times in 30,000km and the last two adjustments were in the last 4 or 5 thousand, which indicates to me that the chain is nearly due for replacement.
Chain slack required relates to the distance between the swing arm pivot and the countershaft sprocket as well as suspension travel.
The closer the countershaft is to the pivot point the less slack needed.
Also a long travel dirt bike will generally require more slack than a road bike.
portly is offline
