Anyone done a TPS adjustment for a 2019XT? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 07-22-2019, 04:00 AM Thread Starter
V650's Avatar
I am trying to test my tps but I don't have the 'dash' or hyphen next to the c00 code. Does anyone know the procedure for this model?20190722_144459_1563778783211.jpg
V650 is offline
post #2 of 6 Old 07-22-2019, 07:06 PM
but why, my 2019xt runs perfectly....
offnote is online now
post #3 of 6 Old 07-22-2019, 09:08 PM Thread Starter
V650's Avatar
Lucky you! I just want to make sure my throttle snatch issue is not an out of spec TPS.
V650 is offline
post #4 of 6 Old 07-25-2019, 04:47 PM
RoadWarrior1978's Avatar
I tried to do the same with my L8 1000 and go the same result, I can only make the assumption it's to do with the latest round of emissions legislation.
I've also noticed that any time a fault is logged it will take three starts and successful runs before the engine management light will extinguish, in the same way as any OBDII equipped car would. I know here in the UK this is the result of EURO 4, it may well have been applied elsewhere as a blanket measure but that's just a guess.
It's not yellow, it's "YELLOW!!!!"
RoadWarrior1978 is offline
post #5 of 6 Old 07-25-2019, 09:43 PM Thread Starter
V650's Avatar
Thanks for that info. Yeah mine is euro 4. I'm assuming adjustment is still possible but it would be using a voltmeter with a break out harness or directly to the pin on the ecu.
V650 is offline
post #6 of 6 Old 07-26-2019, 02:48 AM
That's most likely the case. I've tried to find the necessary specs but not had any luck yet, I bet it'll be in the latest edition of the FSM.
