oil level & filter question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 8Likes
post #1 of 14 Old 07-06-2019, 10:13 AM Thread Starter
SKM348's Avatar
Just changed the oil & filter at my 600 mile interval. I put in 2.7 qts per the manual and the window barely shows any oil? What's wrong?
Filter - I don't have a filter wrench yet but best I can do is 1.75 turns but manual says 2. Am I ok?
Thanks
2019 DL650-XT
SKM348 is offline
post #2 of 14 Old 07-06-2019, 10:19 AM
blaustrom's Avatar
Filter: If there is no seepage at the gasket all is fine. If it gets wet there tighten a bit further. For future consider K&N oil filter. They have a hex head and are easy to put on/ take off.
Oil level: Run the engine a bit. Let sit for a good while then with the bike upright (not on the sidestand) check the level. If its low add some more oil. Don't get hung up on the volume, that info is only indicative, not absolute.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #3 of 14 Old 07-06-2019, 11:18 AM
locoblanco's Avatar
This is a common mistake with new owners. Difficult if you don't have a centerstand. 2.7 liters is the correct amount.
locoblanco is offline
post #4 of 14 Old 07-06-2019, 12:26 PM
RestoRider2017's Avatar
Location: Apopka Florida NW of Orlando near a twist in the road and a hill on the horizon...
Also don't confuse liters with quarts. You can also run the bike just a bit before the oil change maybe 3 minutes
then shut it off. Let cool a few minutes and then pull the plug to drain the oil into your pan. Let sit over night.
if you can. Then remove and change the filter. You can also use a scale to weight the oil amount. Just
zero the container weight. add old oil removed if level was good. Record weight. Then on refill match that amount
using the scale . I keep an old oil jug with a small pour spout just for this purpose. Never been a problem.
Very rarely is the amount of oil you purchase going to be the exact amount you will need...
2017 DL 650 , Shad 23 side bags, Givi crash bars, 32 watt LED driving lights ,
Goldwing pegs, silver front fender, Lazer cut aluminum Chain guard, Madstad 20" windshield
light smoke tint , Blu/blk Driven Racing Billet bar ends, Dbl Take adventure mirrors on order,
Stock exhaust for now. Yoshimura 3/4 system cooking in the oven.
"any jargon or banter heard on this forum is purely for amusement purposes only.
not to be confused with actual motorcycle knowledge"
RestoRider2017 is offline
post #5 of 14 Old 07-06-2019, 03:15 PM Thread Starter
SKM348's Avatar
Thanks all - oil level is fine now, must just take a while to show in window. Called the dlr re the oil filter 2-turn requirement - he said they just turn till snug and never a prob. The torque for the filter is 17ft lbs and filter is ~14.5 ft lbs - never seen such a tight spec!
2019 DL650-XT
SKM348 is offline
post #6 of 14 Old 07-06-2019, 03:25 PM
You will find out that some of the torque specs on these bikes is whacky. Some are just plain wrong.
There is a sticky on this subject so you might want to take a look to see what specs are spoofs.
post #7 of 14 Old 07-06-2019, 04:44 PM
I understand the Suzuki filter can take the two turns due to the way the seals are made. Any other "normal" "standard" oil filter would never need two full turns or that much torque. I like the nut on the K & Ns but probably going back to OEM when I run out of my stock. KN had some QC issues on other size oil filters and some reviews I have read suggest they may not be as great as purported. Kind of hard to tell staring at the package and my thought is Suzuki (or any engine maker) has a lot to lose financially and reputationally so not likely skimping on filter quality.
That said some dufus with spreadsheet may get a promotion by saving 9 cents on filters by getting $.30 filters for two dollars even though they were paying $2.09 for two dollar filters. Dufus would never care about warranty claims, brand reputation as that don't show up in the procurement spreadsheet.
kfh000
kfh000 is offline
post #8 of 14 Old 07-06-2019, 05:17 PM
Highwayman2016's Avatar
The Wix 51359 also is a good filter and it does not need 2 turns.
2014 650 Strom
Highwayman2016 is offline
post #9 of 14 Old 07-06-2019, 06:09 PM
Hogges's Avatar
I have been told decades ago to smear a drop of oil on the new filter rubber seal and then tighten snug by hand only. Never had any leaks doing it this way on any vehicle.
Big B, thecrumb, notacop and 3 others like this.
Hogges is offline
post #10 of 14 Old 07-06-2019, 06:48 PM
Agree with the Wix filter and the drop or two of oil spread on the rubber ring before installation.
On my '12 Wee, with filter change, I'm fairly sure I just pour in 3 quarts of oil and that puts the level at the top mark.
2012 Wee2 Adventure. Black. Bought at 26K miles. Now 44K+. Love it!
HokiesRWee is offline
