NES Throttle Lock - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 05-27-2019, 10:06 AM Thread Starter
rdmnt2002's Avatar
NES Throttle Lock
Hi All,
New member here - thanks for the great forum.
Does anyone use a NES throttle lock on their 650 - and do you like it?
Thanks.
Ray
rdmnt2002 is offline
post #2 of 5 Old 05-29-2019, 11:00 AM
If you meant NEP throttle lock I am using one on my 2018. I had a couple of them from previous bikes and I like them better than any other throttle lock I have tried. I have used NEP on my ST1100, 2004 Wee, 3 Triumph Tiger 800s, FJR and now my 2018 Wee. I don't know which one I have on the 2018 but the tab to keep it from rotating is between the 2 throttle cables. In that location the NEP is rotated lower than I like so I will either cut a groove in it and put it onto the lower throttle cable or rotate it even farther past the lower cable and secure it by some as yet to be defined method. The grip on my 2018 has a groove that goes over a lip on the throttle tube. The NEP needs to go on the grip side of that lip so the grip needs to be shortened. I had a G2 Throttle Tamer from my Tigers so I replaced the original throttle tube with it and then put the NEP on. I also have a throttle rocker on the hand grip to periodically give my hand a rest. I hope to put a Rostra electronic cruise control on the bike soon as I have one of those in my parts collection.
jack d is offline
post #3 of 5 Old 05-29-2019, 08:24 PM Thread Starter
rdmnt2002's Avatar
Thanks for the reply. I tried to correct my post, but could not find the edit option. I had heard you need to make modifications..... it sure I want to do that. I think I will seek other options.
post #4 of 5 Old 05-29-2019, 09:30 PM
Jim Judd's Avatar
I have put the NEP throttle locks on all four of my DL1000s and helped my son put one on his 2019 650XT. There are a couple of mods you have to make to get it to work but you don't have to remove or shorten the rubber grip. You do have to make a spacer to fit under the bracket that would normally attach to a cable housing with a screw and you have to cut two little nubs off of the nylon throttle sleeve. Here are some basic instructions. It doesn't take long at all to do this. The pictures are of my 2019 DL1000 but the 650 is quite similar. The throttle lock to use is the NEP CRUISE CC4-SUZUKI
Before you begin, you will have to roll the end of the rubber grip away from the ridge of the throttle sleeve and trim two little nubs off of that ridge. You may also have to trim a couple of nubs off the inside of the rubber grip. Then the throttle lock will drop right into place:
On the opposite end of the lock, you will see a small piece of wood under the brace that you would normally screw into the throttle housing. It is a spacer I cut from a paint stirring stick (.21” thick) and super glued to the underside of the brace (the gap on the 650 is a little different so adjust accordingly). To that I attached a piece of “hook” Velcro (industrial grade). Make the spacer just long and wide enough for the glue on the Velcro to get a good grip. The “loop” Velcro I stuck right to the throttle cable housing. Because it is not very wide where it attaches, I cut the piece extra wide and rolled it over and stuck it to the side of the housing to give it extra grip to hold.
Mine turned out nice and sturdy and works perfectly. I used a magic marker to color the spacer black to match everything else. It sounds a lot harder than it really is to do. The throttle lock goes in easily once the nubs on the grip housing are removed. The only hard part is anchoring the bracket so it won't rotate.
Hope this helps.
Jim Judd is offline
post #5 of 5 Old 05-30-2019, 04:07 PM Thread Starter
rdmnt2002's Avatar
Jim Judd- Super helpful!!!! Thanks so much for your time and effort!!!!
Manual throttle lock recommendations Mastery General V-Strom Discussion 35 05-13-2019 08:26 AM
Throttle Lock that works with Barkbusters dwayneh DL1000A - 2017+ 21 12-13-2017 09:51 AM
Omnicruise Throttle lock for V2 08Wee DL1000A - 2014-2016 2 07-14-2015 06:26 PM
Oxford Heated Grips + Kaoko Throttle Lock + Hand Guards ??? jtice DL650 and DL650A - 2004 to 2011 5 04-11-2015 10:01 PM
Kaoko Throttle Lock Cruise Control was Before I Pull The Credit Card Out .... Harry Dresden PI DL650A - 2012-2016 23 03-31-2014 04:28 PM
