C16 FI code - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 05-25-2019, 11:35 AM Thread Starter
Eran Kaufman's Avatar
C16 FI code
I had C16 (front speed sensor) cause the sensor broke off, this triggered the Check engine and ABS lights to light all the time.
i just replaced the sensor, and the FI still blinks as before (i didn't ride the bike) do i need to reset the fault or it will go away once i'll ride and the ECU will see a signal from the sensor?
Eran Kaufman is offline
post #2 of 4 Old 05-25-2019, 12:41 PM
I haven't had that specific fault code, but my experience has been that these check engine faults don't clear themselves after your problem is fixed. I have been able to clear out mine by using the following steps.
  • Ride for 10-20 miles
  • Pull over and put the bike into dealer mode (google how if needed)
  • Code will now show as changed to C00
  • Turn the bike off, on and off while in dealer mode
Done!
brock29609 is offline
post #3 of 4 Old 05-25-2019, 12:53 PM Thread Starter
Done!
Thanks
i'll try that
post #4 of 4 Old 05-26-2019, 02:58 PM Thread Starter
So just to update, after a short ride engine off for refueling, lights are off
Help, Fuel Injection code and I'm on the road WingVetteStrom DL650A - 2017+ 19 02-24-2019 02:45 PM
How to clear FI code?? brock29609 Maintenance, Tech and Products. 7 07-23-2018 07:46 AM
C-28 fault code tdewitt DL1000 from 2002-2012 7 06-03-2014 08:27 AM
STVA & TBS, now have C28 error code penzone V-Strom Service and Maintenance Questions and Discussions 15 03-29-2014 10:53 AM
