Specific question about Givi AirFlow - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
post #1 of 12 Old 05-20-2019, 09:31 AM Thread Starter
#motoref
TheCondor's Avatar
I know we have the mega thread above - but I have a specific question.
Has anyone tried the different positions for the "base"? I was wondering if moving that up and down changed anything.
I currently have it in the lowest set of holes - so it can go lower. Moving the lower "wings" up a little might help push stuff out to the side? Just an idea.
I really don't run it much above 2" on the sliders - I don't like the way it shakes.
Scott
Scott Patton
2017 Vstrom DL650A XT
Givi Trekker Dolomiti Cases, SW-Motech Centerstand
Adventure Tech Fork Brace, Customized 4-way Flashers
Adventure Tech RAM Mirror Extenders w/RAM Mounts
Clearwater Darla Light
TheCondor is offline
post #2 of 12 Old 05-20-2019, 09:56 AM
I have mine set to lowest everything, both base and sliding shield. Perfect for me at 5’6” with lower seat option. This way I still look over it at all times. I get a little buffeting from the mirrors but that’s it. You will get a little light glow at night at the bottom of the shield but it’s not a problem, just something I noticed but then quickly got used to.
Hogges is online now
post #3 of 12 Old 05-20-2019, 10:16 AM Thread Starter
#motoref
TheCondor's Avatar
Unfortunately - you're 6" + seat difference below me! I may try it - or just keep riding :-)
Scott Patton
post #4 of 12 Old 05-20-2019, 11:41 AM
The old rule of thumb that the top of the windshield should be somewhere between you chin and nose seems to be true for the Givi Airflow as well. But can’t help you with the three possible base positions. Let us know what you find in case you decide to try it out.
post #5 of 12 Old 05-20-2019, 12:42 PM Thread Starter
#motoref
TheCondor's Avatar
yeah, that's about where I put it... it varies based on temperagure.
I moved it cuz I was bored... we will see.
post #6 of 12 Old 05-20-2019, 01:01 PM
PerazziMx14's Avatar
When I tried the different elevations it made little to no difference at least as far as buffeting was concerned .
TheCondor likes this.
PerazziMx14 is offline
post #7 of 12 Old 05-20-2019, 02:21 PM
I can't speak to the 2017, but on my 2015 DL650, I've tried both lowest and highest positions. Lowest position still had buffeting, but with the added irritation of constantly flipping my helmet visor down (I ride with it up ~99% of the time).
Moving the base to the highest position was a big improvement over the buffeting I experienced in the lowest position.
thirdofthree is offline
post #8 of 12 Old 05-20-2019, 06:35 PM
I have a 2017 and have played with the positioning a fair bit. I am 6’1” tall 185 pounds with a 34” inseam running the stock tall Suzuki seat. I have changed out the stock mirrors for the cheap Aprilia alternatives.
For me, the smoothest airflow is with the lower shield in the highest bolt holes, the upper shield extended up approximately one inch from fully down. Additionally I have a one eighth inch spacer in the lower bolts to open up the bottom (and tilt the top back a little) for better airflow under. This combination seems to work the best for me.
Interestingly with this set-up, 80 mph has smoother air than 70 mph. Prior to the screen tilt, the air would get rougher the faster I went. I am having a little vibration on the helmet at high speeds but it is now very slight and better than many other bikes I have ridden.
thirdofthree likes this.
2017 V-Strom 650
2012 DRZ 400
Jhat is online now
post #9 of 12 Old 05-20-2019, 08:01 PM Thread Starter
#motoref
TheCondor's Avatar
I'll give that a try.
I did move the base to the top holes, and slammed it (it was hot) - and couldn't notice any significant difference around the helmet, but I did notice more air on my chest which was interesting. Will be interesting to try in the cool morning air when you can feel cool in various places.
Scott Patton
post #10 of 12 Old 05-20-2019, 08:21 PM
„Sorry officer, was just trying to get into smoother air.“
The windscreen and buffeting thread for the 2017+ DL650, the only one! greywolf DL650A - 2017+ 277 06-14-2019 05:30 PM
Givi Airflow vs. Madstad bendmac DL650A - 2012-2016 30 03-06-2019 03:28 PM
Question on Givi Mounting Racks Gadget Guy Maintenance, Tech and Products. 6 01-24-2017 09:07 PM
SW Motech Trax Givi Adapter Question Jon148 V-Strom Modifications and Performance 6 12-21-2015 09:22 AM
