Trick to disable ABS - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 2 Post By PerazziMx14
post #1 of 4 Old 05-18-2019, 02:56 AM Thread Starter
I found a post on youtube telling how to disable ABS (good for off road only)
How to turn off or disable the ABS on a Suzuki V-Strom Dl1000, also works on the 650
1°Start the bike and move a bit so the check list is done
2° After the checklist of the ABS and Tracking Control is done stop the bike
3° Turn off the tracking control and put the bike on the central Stand
4° With the Bike on the Central Stand grab the front brake and dont let it go until the full procedure is complete
5°Put the 1 gear speed up a bit, than but 2 gear always pressing the front brake until the ABS light turns ON, after this the ABS is disable
Thanks to Ivo Soares for the trick
juve is offline
post #2 of 4 Old 05-18-2019, 08:16 AM
Location: Now living in Milton, Delaware and in the winter near Sarasota, Florida
Now why go thru all of that just to ride?
Ride till you tire.... Then camp under the stars!
manofsteel1 is offline
post #3 of 4 Old 05-18-2019, 08:39 AM
PerazziMx14's Avatar
Dirt and ABS are not good matches.
Just simply pull the ABS fuse or integrate a switch so you can toggle the ABS power circuit on/off ?
notacop and VstromGrin like this.
PerazziMx14 is offline
post #4 of 4 Old 05-19-2019, 04:57 PM
Sullaha's Avatar
Rolling burnouts and long wheelies are my preferred methods
'17 DL650A -bike # 30 something-
'91 Yamaha SR313 Tracker
'97 BMW F650 "Die Haifisch"
'19 Indian FTR 1200S (when it F#%king gets here!)
D.A.S.C for life!
Sullaha is offline
remove the kickstand helper or disable the cutoff switch? kgoess Maintenance, Tech and Products. 5 02-01-2019 10:55 AM
Disable ABS with switch HOW TO???? johnwalton DL650A - 2012-2016 41 02-17-2017 09:43 AM
Disable ABS? Kankujoe DL650A - 2012-2016 7 08-22-2012 12:21 PM
Disable headlight interrupt juddspaintballs DL650 and DL650A - 2004 to 2011 3 10-23-2011 10:15 PM
Trick to remove fuse box? FiremanBob V-Strom Service and Maintenance Questions and Discussions 4 10-31-2010 08:57 PM
