gheto fork mods - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
post #1 of 12 Old 05-06-2019, 04:17 PM Thread Starter
Eran Kaufman's Avatar
gheto fork mods
Hi guys, was thinking on trying some old school method from my DR days.
Adding a longer spacer and some more oil to the fork?
will it do any good?
i'm ~260 Lbs so the fork is relay soft for me.
being OUS means that all the nice stuff you guys can get for the forks is always double the price for me
Thanks
Eran
Eran Kaufman is offline
post #2 of 12 Old 05-06-2019, 05:37 PM
Mike Ford's Avatar
Use some thicker fork oil too
Mike Ford is offline
post #3 of 12 Old 05-06-2019, 06:03 PM
Bazooka Joe's Avatar
You can do the "free stiffer spring" mod to get stiffer fork springs. I modded mine many years ago. The results were similar to .90 springs, which IMO, would be about what you would need for your weight. Hope this helps.
https://www.stromtrooper.com/dl650-d...ings-free.html
18 1000 XT yellow. Bunch of goodies installed.
2015 Yamaha WR250F- Street plated woods bike
Previous rides- about 25 different bikes, mostly dirtbikes.
Bazooka Joe is offline
post #4 of 12 Old 05-06-2019, 06:36 PM
PerazziMx14's Avatar
Adding a spacer add preload to the existing spring. Thicker oil adds dampening. More oil lessens the air chamber and increases the chance of hydrolock. None of the above increase the spring rate.
Cheap works arounds usually garner mediocre results. Trust me this is coming from a guy about your size and take no offense. Why not do the cheapest and best thing for yourself and try to lose 20, 30 or 40 pounds?
PerazziMx14 is offline
post #5 of 12 Old 05-07-2019, 09:28 AM
#motoref
TheCondor's Avatar
And with the money you saved from not eating as much spend $100 on a set of springs and get it right.
Scott Patton
2017 Vstrom DL650A XT
Givi Trekker Dolomiti Cases, SW-Motech Centerstand
Adventure Tech Fork Brace, Customized 4-way Flashers
Adventure Tech RAM Mirror Extenders w/RAM Mounts
Clearwater Darla Light
TheCondor is offline
post #6 of 12 Old 05-07-2019, 10:28 AM
According to the OP that $100 spring set would cost him closer to $200. For all we know spending $100 let alone $200 may not be doable. We also don't know anything about his physique so losing a bunch of weight may not be an option. And even if it is maybe he wants to ride his bike while he waits for that much of a weight reduction to be safely accomplished.
jack d is offline
post #7 of 12 Old 05-07-2019, 10:57 AM
I understand if the OP doesn't have the coin to dedicate to getting new springs but there is no substitute. Add more preload, heavier oil or less head space will not do what he wants.
post #8 of 12 Old 05-07-2019, 12:30 PM Thread Starter
Intimators seems to bee the simplest add on improvement, do they relay dont require changing the springs?
Does anyone know why wont they ship to the UK?
P.S, They cost 179$ and shipping to Israel is additional 144$
post #9 of 12 Old 05-08-2019, 11:09 AM
You can certainly increase spring pre-load in your front forks with the addition of washers/spacer, but the downside of that is that you lose some fork travel due to early spring coil bind. Using thicker oil will decrease your initial compression travel, but the downside is you will lose bump compliance and fork rebound response, possibly causing "packing" of the front fork under braking during aggressive riding. If you want to improve your suspension performance and compliance, stiffer springs and either the RaceTech Gold valves or the Intiminators are the answer.
badjuju is offline
post #10 of 12 Old 05-08-2019, 03:39 PM
Intiminators add rudimentary "valving" to the damper rod forks that actually works quite well in comparison to the straight up old out dated by at least 40 years damper rod technology.
But again they will not do anything to improve the spring rate. In my opinion Itiminators are worth the money but are only part of the solution. Springs and the right fork oil also.
Do you have any friends or family in the USA that can buy the component and then thy ship then to you? I shipped a cast iron skillet to Singapore and I thought $45 was ridiculous. I can't imagine it really costing $144 to ship a 1 pound package of Intiminntors to Israel. Heck it might be worth a plane ticket to fly here tour around buy a bunch of stuff and carry it home.
Possible to adjust front suspension on a DL1000 K2? Halisko DL1000 from 2002-2012 10 08-09-2017 02:31 PM
Fork Brace warning swisstrom DL650A - 2012-2016 45 04-22-2017 07:22 PM
Installing Racetech Springs with Gold Valve Emulators on 650 lacofdfireman Suspension and Tire Tech 18 11-23-2016 07:13 AM
Fork seal change CaliScott V-Strom Service and Maintenance Questions and Discussions 3 05-22-2016 12:57 PM
Fork oil height/sonic 1.1 springs hunt1moore DL1000 from 2002-2012 16 09-22-2014 07:23 AM
