Question Regarding unused connectors from factory. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 5Likes
post #1 of 20 Old 05-05-2019, 10:23 PM Thread Starter
BigSky's Avatar
I've seen numerous references in various different threads about some unused/capped connectors on V-stroms as they come from the factory. Heated grip wiring, auxilliary wiring, etc., are just some of the things I've seen referenced. So, how many of such connectors are there? Where are they all located? I'm an electrical novice; so, for what can they be used? I'm assuming they can be used for any accessory one wants. This would be an easy way for me to forego running additional wire in the future. I placed this in this forum because I own a 2017 DL650 XT.
BigSky is offline
post #2 of 20 Old 05-05-2019, 11:36 PM
K9 Wee's Avatar
Eastern Beaver is your friend. They have excellent reputation, solid engineering and a ready-made solution to providing power to your accessories--switched or unswitched.
Not avoiding your query, just forwarding some potentially useful information. There are unused plugs available on Stroms for items such as heated grips, etc. that were not factory installed. Those are still an option, but the pre-engineered solutions available make these tasks much easier.
Webfors likes this.
______________________
2009 Orange DL650
SW Motech Rally Crashbars, Skidplate & Centerstand
Givi e22L Sidecases
Shad 33L Topcase
Wolfman 40L Waterproof Duffel
Givi Tanklock 20L Tankbag
Techiwik Long Underwear
1978 Honda CB550K-Sold
K9 Wee is offline
post #3 of 20 Old 05-06-2019, 07:38 AM
+1 for eastern Beaver. I ran their stuff on my previous Vstrom, bought some non bike specific things for other bikes I've owned, and am currently running their stuff on my current vstrom.
They have connectors that use those unused plugs, and also a few things that split off from current plugs (for example, if you want a switched relay, they have one that ties into the break lights I believe)
I might even put their little Beaver power sticker on my saddlebag!
K9 Wee likes this.
sfalexi is offline
post #4 of 20 Old 05-06-2019, 08:50 AM
You have to look at the size of the fuse that protects the circuit you're tapping into. You can't overload the fuse.
The accessory plug doesn't have anything drawing from it. It's on a 3A fuse so you can tap into those wires for small things like a phone, GPS or small LED spots, but you ain't hooking a heated jacket liner to it.
Fuse #2 protects the unused heated grip fitting. It's on a circuit along with your horn, dash & all non-headlight lighting. With no heated grips added you probably have about 3A of bandwidth there too since that's the approx draw of heated grips.
Safe bet is always to create a new direct-to-battery circuit with in-line fuse holder and relay. Loads on of how-to info out there on doing this.
DesertBike likes this.
brock29609 is offline
post #5 of 20 Old 05-06-2019, 08:53 AM Thread Starter
BigSky's Avatar
Thanks guys. However, I have enough Eastern Beaver stuff to open an outlet store. Heck I even use it for my boat and my pickup.
On another note, I've seen numerous references in various different threads about some unused/capped connectors on V-stroms as they come from the factory. Heated grip wiring, auxilliary wiring, etc., are just some of the things I've seen referenced. So, how many of such connectors are there? Where are they all located? I'm an electrical novice; so, for what can they be used? I'm assuming they can be used for any accessory one wants. This would be an easy way for me to forego running additional wire in the future.
Thanks for that information brock29609.
BigSky is offline
post #6 of 20 Old 05-06-2019, 10:10 AM
I'm only aware if the heated grip connector, however, there's no reason to go chasing connectors. There are wires all over the bike that you can tap into. The ones running down the left side to the rear lighting is the easiest to get access. Same circuit as the heated grip connector.
post #7 of 20 Old 05-06-2019, 11:12 AM Thread Starter
BigSky's Avatar
I've read people discussing at least one other unused auxiliary connector. Of course, they could be wrong. That's why I posted this thread.
.........there's no reason to go chasing connectors. There are wires all over the bike that you can tap into.
I know. However, that doesn't let one know about the unused connectors that exist.
I know, I've done that.
The ones for my rear lighting run down the right side and I have tapped into that/those.
That I did not know. Very interesting.
Onto the topic of this thread, Does anybody know how many there are and where they are all located? I think we are agreed that the heated grip connector is 1. I've heard/read reference to others. Curiosity is it. I just thought it would be easy to put that inquiry out there for anybody who might know.
BigSky is offline
post #8 of 20 Old 05-06-2019, 01:13 PM
The wiring diagram shows only the one for grips, if that means anything to you.
For clarity for those reading, rear lighting wires run on left side from battery rearward. Not sure if they also extend from the front half.
post #9 of 20 Old 05-06-2019, 02:31 PM Thread Starter
BigSky's Avatar
The wiring diagram shows only the one for grips, if that means anything to you..
It does. Thank you. Apparently the others are mistaken.
For clarity for those reading, my apologies as I don't assume you are all as big of morons as I am. I made the, apparently false, assumption that the brake light wires (which are on the right side of the bike as pictured below - white plug with white wires) and the "rear lighting wires", as mentioned by brock29609, ran together. So as to not create confusion, if you order a PC-8 from Eastern Beaver, it's plug fits right into that junction/plug on the right side of your motorcycle. Maybe there is a matching one on the left side for other rear lighting. If so, I didn't mean to make you think you couldn't use it. This is the one (right side, pictured below) I was directed to use by Jim at Eastern Beaver.
BigSky is offline
post #10 of 20 Old 05-06-2019, 02:35 PM Thread Starter
BigSky's Avatar
Oh, and in case I'm wrong again. As I've stated previously, I am an electronics moron. I may have made a different false assumption. What I do know is unplugging the pictured connection above, my brake lights don't work. Plugging it back in, they work. Maybe it's not the brake wire; but, it definitely has that affect AND the PC-8 powers up and acts as it should as I was promised by Jim at Eastern Beaver.
BigSky is offline
Question Regarding Voltage Monitor Installation BigSky V-Strom Modifications and Performance 8 04-30-2019 10:21 AM
Accessorie plug - Voltage indicator/reading Patrol DL650A - 2012-2016 2 06-05-2017 10:50 PM
Odd behavior - Gear voltage levels are not stable BigMan73 Techy World! GPS, Electronics, etc 41 04-13-2012 05:48 AM
Gear Position Switch connectors BobA DL650 and DL650A - 2004 to 2011 12 01-20-2012 04:35 PM
Low Voltage Wee South DL650 and DL650A - 2004 to 2011 11 05-18-2011 11:47 PM
