Rigid Ignite LED light Install - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 2 Old 05-05-2019, 04:38 PM Thread Starter
dean.peckford's Avatar
I purchased these lights by Rigid, very small, low current draw. I have one spot and one flood. I have been trying to find the best place to install them. I considered the crash bar, but I was concerned that they might detract from the effectiveness of the turn signals. So I think I have found a suitable location. The reflectors on the forks look like a good spot. The studs on the reflectors are M5, so I replaced the screws on the Rigids with 30mm long M5 bolts, and the lights bolt on perfectly. Looks very good. As well I found a place for the switch on the handlebars. Now I'll have to remove some body work and the tank to run the wiring back to the battery. I am going to use a relay ( not because of current draw but so I can wire it to a switched source to ensure the lights are unpowered when the key is off. I will update when I get these wired with a report on effectiveness as well.
Past Bikes
2017 Suzuki DR650se, 2013 Suzuki DR650se, 2008 Suzuki M50 Boulevard, 1973 Kawasaki 750H2, 1978 Yamaha XS400
dean.peckford is offline
post #2 of 2 Old 05-05-2019, 04:40 PM Thread Starter
A few more photos
Past Bikes
How to install /replace front signal light housing Vstrom650Goliath DL650 and DL650A - 2004 to 2011 8 07-26-2017 03:53 PM
Throttle Body Butterfly Sync (NOT idle air needle adjustment sync) dmfdmf V-Strom Service and Maintenance Questions and Discussions 1 04-11-2017 03:56 PM
Tail light, brake and rear turn signal wiring Stoopy DL1000A - 2014-2016 35 09-11-2015 11:30 PM
Whelen TIR3 LED light install, brake wire location? ak85lp DL650 and DL650A - 2004 to 2011 4 07-03-2014 11:10 PM
