Coolant temp problem? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 6Likes
  • 1 Post By Rolex
  • 1 Post By blaustrom
  • 1 Post By byrdock
  • 2 Post By Big B
  • 1 Post By Rolex
post #1 of 10 Old 04-28-2019, 11:56 PM Thread Starter
I took my '17 V-Strom up to the mountains this weekend so the Boss could get some off-road experience with her Versys-X-300.
While we were taking it slow and easy on the gravel roads (5-15mph) my cooling fan came on a few times but the coolant temp gauge only had 3 bars showing. I was expecting the temp to go up crawling around for 15 miles and kept checking on gauge but it always had just 3 bar showing and didn't change when fan was running. Has anyone had this happen before? Thanks.
byrdock is offline
post #2 of 10 Old 04-29-2019, 02:07 AM
Rolex's Avatar
I would say that's normal,.
The temperature was high enough to bring on the fan and the fan worked well so the temperature did not climb any higher.
The 3 bars is set by the thermostat not by the fan.
Hatchi likes this.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #3 of 10 Old 04-29-2019, 02:51 PM
blaustrom's Avatar
+1
Don't worry and ride more, all is well.
Hatchi likes this.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #4 of 10 Old 04-29-2019, 09:29 PM Thread Starter
So the gauge is there to let you know if the thermostat goes bad then. I didn't stop riding, just wanted to make sure there wasn't a problem that needed attention. Thanks!
Hatchi likes this.
byrdock is offline
post #5 of 10 Old 04-29-2019, 09:42 PM
jgendr's Avatar
Don't try to fix what ain't broke.... LOL
2014 DL650 VStorm
jgendr is offline
post #6 of 10 Old 04-29-2019, 10:05 PM
Mine has NEVER moved off 3 bars once up to temp, that's common practice for the 650's.
Hatchi and Motorpsychology like this.
post #7 of 10 Old 04-29-2019, 10:14 PM
Thermostat is there to let you know if the engine is overheating. There are more causes for this than simply a malfunctioning 'stat.
Severe overheating can warp the heads, lead to deterioration of the oil and failure to lubricate and other expensive engine damage.
Ratchet is offline
post #8 of 10 Old 04-29-2019, 10:22 PM
blaustrom's Avatar
The temperature warning is just that. It gives you a warning in case there is a malfunction (like loss of coolant, radiator fan not working, coolant temperature sensor defect … ) in the cooling system. No different than any car.
As long as it stays "in the middle" all is well.
Blau2 2014 DL1000A
post #9 of 10 Old 04-30-2019, 12:28 AM
Rolex's Avatar
The thermostat is there the bring the motor temperature up as quick as possible then maintain that temperature.
The fan is to bring the temperature back down if it gets high.
Motorpsychology likes this.
2014 V2, Snoopy
Rolex is offline
post #10 of 10 Old 05-05-2019, 12:36 PM
Motorpsychology's Avatar
As long as the red warning light doesn't come on, your'e good to go. If there is a problem, either the oil or temp symbol will come on along with the red light.
18 wheels move the cargo, 4 wheels move the body, 2 wheels move the soul -unknown
“Of all the paths you take in life, make sure a few of them are dirt.” - John Muir
I visited the Air & Space Museum- didn't see a thing...
Motorpsychology is offline
4 codes and cloudy coolant Nelsonmd DL1000 from 2002-2012 3 11-12-2016 10:31 PM
Water Pump leaking after coolant change? blaustrom V-Strom Service and Maintenance Questions and Discussions 3 04-29-2014 02:39 PM
oil temp vs coolant temp Boit4852 V-Strom Service and Maintenance Questions and Discussions 2 06-18-2013 01:56 AM
Coolant leak(from the overflow hose)!!! snatch V-Strom Service and Maintenance Questions and Discussions 16 01-28-2008 06:54 PM
