Is this standard? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 7Likes
post #1 of 20 Old 04-28-2019, 05:58 PM Thread Starter
Is this standard?
On a 2017 DL 650?
Connected to the battery - either for charging or tapping power?
Regards, Lars.
bonne is offline
post #2 of 20 Old 04-28-2019, 06:00 PM
Umbrianissimo's Avatar
Looks like a connector for hooking up a battery tender. Good to have as you don't need to remove the seat.
Brockie likes this.
Damon
2017 DL 650 and maybe another Vespa?
I'm having an adventure- so, its an adventure bike.
Now that summer is here, I'm retiring so I can ride full time.
Umbrianissimo is offline
post #3 of 20 Old 04-28-2019, 06:06 PM
David Waldo's Avatar
That is the way I did my battery tender
2011 DL650A, 2008 C50T
David Waldo is online now
post #4 of 20 Old 04-28-2019, 06:08 PM
Boy....I mean, I'm no expert, but I find it hard pressed that a factory would do that ziptie job... or even ziptie something like that there...
HOWEVER... if it's connected to the battery, that's a great thing to have in general. Battery tender, heated gear, portable air compress to fill tires, it's a great handy little plug to have around! They saved you a couple bucks and a little time of installation. Congrats!
sfalexi is offline
post #5 of 20 Old 04-28-2019, 08:05 PM
blaustrom's Avatar
Battery tender pigtail.
NOTE: If you have a compressor to fix a flat/ puncture make sure the pigtail is fused at least with a 15A fuse or else you cant fully inflate the tire. How do I know ?
Big B and emjrrider like this.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #6 of 20 Old 04-28-2019, 09:03 PM
That is not Factory issue. I have the same connector going to my Eastern Beaver fuse panel that I use for a battery tender or filling a tire. Great to have. Also have one up by the handle bars.
Bob S.
2017 Vstrom 650 Base model (White)
2017 Yamaha YZ250X (Sold)....Hopefully WR250R soon
Previous loves:
1982 Yamaha 650 Seca
1978 Honda CB550
1975 Suzuki GT380
1977 Yamaha RD400
1973 Can Am MX1 125 (bought while Mom out of town)
Nicad is offline
post #7 of 20 Old 04-28-2019, 10:36 PM
gspy4u's Avatar
Have the same connector, definitely for battery tender
gspy4u is offline
post #8 of 20 Old 04-29-2019, 07:07 AM
Webfors's Avatar
Hmm.. I thought the BT used an SAE type plug. That looks more like a connector for a Ctek battery charger.
Two wheelz for realz!
Webfors is offline
post #9 of 20 Old 04-29-2019, 08:50 AM
snorkie's Avatar
I'm amazed people and their electric pumps. When my tire(s) get low on my car/bike, I get out my bicycle pump. It has a pressure gauge and is about 4x faster at pumping up a low tire. I've never blown a fuse/back using it. A small manual pump can be carried and weighs even less and always works.I can't be the only one that does this.
snorkie is offline
post #10 of 20 Old 04-29-2019, 09:01 AM
RCinNC's Avatar
That's a pigtail of some sort, but I don't think it's specifically a Battery Tender (as in the brand name "Battery Tender"). The plug on mine doesn't quite look like that. Is it possible that this is what a pigtail looks like for a lithium battery, like a Shorai?
I doubt that it's factory. That black and red wiring is the kind of stuff I buy from electronics supply houses for various projects; it's the same stuff I used to wire in my USB and 12 volt outlets. I've never seen that sort of zip wire as a factory thing.
Motorpsychology likes this.
RCinNC is online now
Adventure or Standard murdock2002 DL1000A - 2014-2016 15 08-12-2015 08:18 AM
Standard sprocket sizes front and rear and how many links on standard chain? Danie DL650 and DL650A - 2004 to 2011 3 03-23-2010 11:56 AM
Standard Wee-Strom tool kit. joe watson General V-Strom Discussion 2 08-31-2009 08:59 AM
madstad MP vs standard jeromeb DL650 and DL650A - 2004 to 2011 5 01-29-2008 06:16 PM
