Changing headlight bulb? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 1 Post By hatrick
  • 1 Post By Mingo
post #1 of 8 Old 04-14-2019, 01:16 AM Thread Starter
#motoref
TheCondor's Avatar
Anybody changed one? Any tips on removing that top bulb?
Scott Patton
2017 Vstrom DL650A XT
Givi Trekker Dolomiti Cases, SW-Motech Centerstand
Adventure Tech Fork Brace, Customized 4-way Flashers
Adventure Tech RAM Mirror Extenders w/RAM Mounts
Clearwater Darla Light
TheCondor is offline
post #2 of 8 Old 04-14-2019, 03:31 AM
hatrick's Avatar
Just looking at the placement of the globes and owning a Taxi for many years with similar setup its not that difficult, be aware don't touch the actual globes as grease of your fingers will cause them to fail prematurely.
notacop likes this.
hatrick is offline
post #3 of 8 Old 04-14-2019, 08:45 AM Thread Starter
#motoref
TheCondor's Avatar
Looks like you have an older model. 2017 is different.
Scott Patton
post #4 of 8 Old 04-14-2019, 04:45 PM
blaustrom's Avatar
If its similar to the V2 then you need to remove the instrument panel, 2 screws and 2 push rivets. Then carefully pry them apart. They are held by plastic clips along the top. Then disconnect the instrument connector and the electrical outlet connector. Then it's obvious and right in front of you.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #5 of 8 Old 04-15-2019, 05:40 AM Thread Starter
#motoref
TheCondor's Avatar
Similar.
You have to pull the panel, which takes a couple more steps. Not hard.
File Type: jpg IMG_20190414_145300_403_1555321207387.jpg (2.90 MB, 20 views)
Scott Patton
post #6 of 8 Old 04-15-2019, 10:55 AM
Location: San Jose, California, USA, North America, Earth
Before you remove the dashboard, you need to remove the trims that are attached to the dashboard. More screws and more small pieces to remove!
TaubBaer is offline
post #7 of 8 Old 04-15-2019, 11:07 AM
Mingo's Avatar
I just did this. you have to remove the 2 colored panels that join to form the "beak".. Look at Dr. Vstrom's video on how to remove the fuel tank on Gen 3 Vstrom 650. Once you remove the 4 fasteners on the under side of the beak panels, you have to slide them forward to detach them, then you can remove the plastic pop rivets around the instrument panel, then you remove the instrument panel to access the H7 low beam bulb. I replaced mine with an LED bulb so hopefully, I won't have to do this again. It's not hard to do, but not as easy as replacing the H9 high beam bulb.
TheCondor likes this.
Mingo is offline
post #8 of 8 Old 04-15-2019, 11:50 AM
blaustrom's Avatar
Originally Posted by TheCondor View Post
Similar.
When you put it back together make sure that the rubber cover over the instrument plug is securely covering and sealing that plug against water ingress.
Blau2 2014 DL1000A
Headlight bulb 13 DL650A ianbh DL650A - 2012-2016 3 09-25-2018 06:14 PM
Lower Headlight Bulb? Bville-Bud DL1000A - 2014-2016 6 11-27-2015 06:09 PM
Headlight bulb went out this morning, need some help finding a replacment part. bobosmite DL1000A - 2014-2016 6 03-19-2015 12:27 AM
