standing on pegs weird position? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 6Likes
  • 2 Post By Webfors
  • 2 Post By KSM
  • 2 Post By richlandrick
post #1 of 8 Old 04-13-2019, 08:00 PM Thread Starter
I tested yesterday new 650xt and I couldn't stand on pegs for long, very awkward, not stable position along with low, too close handlebar..
why is that? I'm 6.1, anyway to fix that?
offnote is offline
post #2 of 8 Old 04-13-2019, 08:10 PM
Webfors's Avatar
I put SW-Motech pegs on, with 1 inch barbacks and the standing position is perfect for me. But I'm 5'8.
Different risers and foot pegs can fix any riding position.
notacop and reasonable like this.
Two wheelz for realz!
Webfors is offline
post #3 of 8 Old 04-13-2019, 09:23 PM
i got a set of 1" risers and a set of 1200GS risers that provide a bit more rise and back. Those provide for more secure standing on the pegs riding. If you do much dirt bar risers make it more comfortable.
Various peg adjustments can help too.
notacop is online now
post #4 of 8 Old 04-13-2019, 09:46 PM
KSM
KSM's Avatar
I’m 6’3”. Added a peg lowering kit and 2” Rox risers up and forward. Dramatically improved the stand up (and seated) ergos for me.
richlandrick and Motor7 like this.
2012 DL650A (purchased Dec 2017)
2005 DRZ400S (sold Dec 2017)
1972 Norton Commando (sold 1984)
1978 Suzuki DR370 (sold 1982)
KSM is offline
post #5 of 8 Old 04-14-2019, 05:47 AM Thread Starter
but when you guys lower pegs ground clearance which is not big anyway will decrease, right?
which exactly lowering kit are you talking about?
offnote is offline
post #6 of 8 Old 04-14-2019, 08:40 AM
Stromtrooper.com Sponsor
richlandrick's Avatar
Yes, that is normal for taller people.
Try our foot peg and control lowering kit. It lowers both the pegs and the controls. Lowering only the pegs causes a weird reach to the controls and is limited to about 3/8". Our peg lowering kit lowers everything an inch. Pegs, gear shift, and brake pedal. It improves the posture of the lower back and reduces bend at the knee. All for about 1/5 the cost of some lower pegs.
https://www.adventuretech.biz/footpe...ering-kit.html
If you have problems getting your boot under the shifter check this out.
https://www.adventuretech.biz/gear-s...extension.html
Beware expensive handlebar risers. Look around and you can find simple 1" risers for $25 or less, or spend close to $100 for the same benefit and a lot of aggressive costs. Or better yet check out the 2" nd 3" risers from Rox. They cost more, but in their case they are worth the money.
You can replace the brake top line on DL650 to accommodate the higher handlebar without the cost of replacing the entire brake line system. The clutch and throttle cables can be repositioned and work fine.
https://www.adventuretech.biz/2-brake-line-options.html
badjuju and offnote like this.
richlandrick is online now
post #7 of 8 Old 04-14-2019, 02:06 PM
KSM
KSM's Avatar
Doesn't reduce ground clearance because the pegs are still higher than the skid plate. Reduces the lean angle you can go into corners before you drag the pegs but only marginally.
KSM is offline
post #8 of 8 Old 04-14-2019, 08:54 PM
K9 Wee's Avatar
Your options are limited. You can use a peg-lowering kit and bar risers or you can learn to use front and rear pegs at same time to place your body in the most comfortable and effective stance, lastly, you can learn to use front pegs only with a bent knee stance that will allow you to ride standing up for as long as you wish--leg strength and balance notwithstanding. Entirely up to you.
______________________
2009 Orange DL650
SW Motech Rally Crashbars, Skidplate & Centerstand
Givi e22L Sidecases
Shad 33L Topcase
Wolfman 40L Waterproof Duffel
Givi Tanklock 25L Tankbag
Techiwik Long Underwear
1978 Honda CB550K-Sold
K9 Wee is offline
2015 xt standing on the pegs issues. Rontopia DL650A - 2012-2016 15 11-03-2016 04:55 PM
Legs hitting plastic side covers standing on pegs XT Townsville DL650A - 2012-2016 3 01-26-2015 07:10 AM
Standing on pegs tutorial? BabaAus Riding Proficiency 29 11-10-2013 11:19 PM
Off road tips? Bigmuff General V-Strom Discussion 28 08-13-2013 12:42 AM
