front suspension - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
post #1 of 17 Old 04-10-2019, 11:09 AM Thread Starter
dryhte's Avatar
Question front suspension
Hi guys,
has anyone here done anything about their front suspension (fork springs)?
While I find the rear shock quite adequate, I find the front fork both jarring on potholes and bumps, AND it dives a lot while braking.
I wonder if there's an easy way around this. What have others done? (of course option A is to live with the bike as it is).
Any other options?
dryhte is offline
post #2 of 17 Old 04-10-2019, 11:37 AM
Can't speak to the latest gen, but I did a fork upgrade on my '09 with RaceTech springs and their Gold valves (similar to an emulator). The valves act as a "big hit" release/bypass valve so that you get nice compliance on small bumps or rough pavement but a softer response on the major bumps. Fresh fork oil in a 15 wt also helped. I assume that RT makes fork accessories for the latest Wee model, or will in the near future. For that matter, the forks may be identical internally to the older gen.
badjuju is offline
post #3 of 17 Old 04-10-2019, 03:43 PM
Big Boy's Avatar
If you want to have them rebuilt to your weight and riding style I suggest contacting Daugherty Motorsports. He can rebuild them any way you want and for a pretty reasonable price!
DMr Performance Suspension ? Performance Motorcycle Suspension and Chassis
W. C. Fields
Big Boy is offline
post #4 of 17 Old 04-10-2019, 05:41 PM
blaustrom's Avatar
Get some Ricor Intiminators, keep the stock springs. Use DMr for your shock.
Dread7 and Pepe lopez like this.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #5 of 17 Old 04-10-2019, 07:22 PM
KSM
KSM's Avatar
+1 on Jamie at DMr. He sent me new springs and emulators which I installed. Required a little research, several hours over a weekend and a drill press. Huge improvement to the front suspension. Parts were around $200.
Just noticing it looks like you're in Europe. Lot's of options over there, I'm sure.
2012 DL650A (purchased Dec 2017)
2005 DRZ400S (sold Dec 2017)
1972 Norton Commando (sold 1984)
1978 Suzuki DR370 (sold 1982)
KSM is offline
post #6 of 17 Old 04-10-2019, 08:02 PM
Administrator
Stock springs are too soft for the majority of us, but proper springs/oil for weight and riding style is typically all which is needed.
post #7 of 17 Old 04-11-2019, 12:06 AM
bendmac's Avatar
Sonic springs and different fork oil
I'm 6'2"/230# on my 2013 Wee...probably an 85/15 to 80/20 rider.
I did an upgrade to .95 Sonic springs and 15wt fork oil.....schweeet! Much more planted, less front dive when grabbing a handful of front brake and just a generally better feel on the road.
Not a terribly expensive upgrade, well worth the time and fundage. Between the front springs and having the rear stock shock rebuilt by Sasquatch, bike is right where I want it.
Cheers..
Bendmac/Central Oregon
2013 Wee Adv...
EnduroGuardian bash plate/highway pegs/radiator guard;
AdventureTech LLC peg lowering mounts/mirror extenders/fork brace/shifter relocation kit, 2" extended front brake line;
Saddleman Gel-Channel Tech seat;
Barkbuster Storm hand guards;
Oxford heated grips;
Blue Seas 5025 6 circuit fuse block;
12v weatherproof power port;
Eastern Beaver headlight relay kit;
Cree LED lights;
Signal Dynamics voltage monitor;
Kisan signalMinder
PWD Stebel horn kit;
"Home grown" tool tube;
"Sasquatched" (Adventure Power Sports) rear shock
Madstad bracket and 22" screen
Roadstercycle SH775 R/R upgrade
SW-Motech bar risers
Mr. Ed's Moto custom seat
bendmac is offline
post #8 of 17 Old 04-11-2019, 10:16 AM
Big Boy's Avatar
One option would be to contact Jamie (owner of Daughtery Motorsports) and ask for his recommendation of a Euro suspension specialist.
Good Luck
W. C. Fields
Big Boy is offline
post #9 of 17 Old 04-11-2019, 04:49 PM
blaustrom's Avatar
The stronger spring in the rear is more important, that's where most of the rider weight and all the stuff we carry is. I ran the Intiminator with stock springs in the front and it was a big improvement. They are easier to ship to Europe as well ;-)
Blau2 2014 DL1000A
post #10 of 17 Old 04-16-2019, 10:39 AM Thread Starter
dryhte's Avatar
Thanks all. I'll look into the intiminators. But do they need to be set up, or can they be dropped in just like that?
dryhte is offline
Extended front brake line, '13 Wee ABS bendmac DL650A - 2012-2016 21 12-15-2018 07:50 AM
Front Suspension kmsz1969 DL650A - 2012-2016 38 05-01-2018 12:43 PM
Front suspension problem!? Jjfriscia Suspension and Tire Tech 11 06-30-2014 08:50 AM
Sorting the front Suspension mudrat V-Strom Service and Maintenance Questions and Discussions 2 08-13-2011 03:42 AM
I almost wrecked last night timbo813 General V-Strom Discussion 64 07-16-2010 08:16 AM
