2017+ lowering links and side stand - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By Rum Runner
post #1 of 8 Old 04-08-2019, 12:22 AM Thread Starter
stevet's Avatar
I used Murph's Kits 3/4" lowering links on my previous '07 DL650, and then had to shorten the side stand to keep the bike from tipping over. It stood about vertical with the lowering links, just touching the right side saddle case was enough to tip over the bike.
Would I be able to install the same 3/4" lowering links on my 2018 DL650 without shortening the side stand? Will the bike confidently stand upright with enough lean, not just be "pretty good but the side stand should still be shortened"?
I also use an Adventuretech side stand plate, that already stands the bike fractionally more vertical, but still very much has good lean to prevent a right side tip over.
Thanks for sharing your experience.
Steve.
stevet is offline
post #2 of 8 Old 04-08-2019, 01:54 AM
chirosyd's Avatar
Steve,
I lowered my 2011 vstrom 650 1" when I first purchased it. I did not shorten the kickstand, and probably should have.
When I lowered my 2014 Vstrom 1000, I also had the kickstand lowered 1". I was very happy with the results. I initially tried Soupy's adjustable height kickstand, and was not satisfied with its' functionality.
It should be very obvious once the lowering links are installed, how the bike sits and the need for any/how much lowering.
Good luck
chirosyd is online now
post #3 of 8 Old 04-08-2019, 06:02 AM
I installed a 1” lowering link on my 2017 DL650 and I cut a good inch and a quarter (1.4” theoretical if the stand is at a 45 degree angle to the floor) out of the sidestand tubing and then welded it back together. The front is also lowered by about a 7/8”. Except for the fact that I welded the kickstand back together at a slightly wrong angle (toe sticking up a bit) it turned out to be perfect, especially with a sidestand foot enlarger installed.
Hogges is offline
post #4 of 8 Old 04-09-2019, 07:19 AM
Rum Runner's Avatar
2017 V-650. I did the Adv-Tech. 7/8 lowering links and absolutely no issues with the side stand. However I have not as yet lowered the front forks, and may not. Rode my trusty KLR for years with the rear lowered and not the front and actually liked it that way. I did have to get a new side stand with the KLR though.
richlandrick likes this.
Rum Runner is offline
post #5 of 8 Old 04-09-2019, 10:34 AM Thread Starter
stevet's Avatar
Rum Runner, what are the handling characteristics of your front end being relatively higher than the rear end? I'm guessing straight line stability is good (improved?), but steering is a bit slower and takes a bit more effort? Or, something completely different?
Thanks,
Steve.
stevet is offline
post #6 of 8 Old 04-09-2019, 11:01 AM
Rum Runner's Avatar
Difficult for me to make a call on that at this time. Bike is too new as I need more seat time on it. I got the V mostly for ADV road trips and have other bikes for more or less daily use. Havenít even finished my first break in miles yet. But plan is get first oil change done this week then take a run in the mountains this weekend and maybe an overnight camping trip. Ya thatís the ticket
post #7 of 8 Old 04-10-2019, 04:47 PM
I had Soupy's adjustable sidestand and oversized foot on my 2014 650 which I lowered the same amount (3/4"). I tried it with the stock stand for a couple days after lowering it and felt it was a bit unstable on the hills in the Bay Area. The sidestand was definitely a bit pricey for what it was but I ended up getting one used of the forum. Looks like the same one fits the new 2017+ model so you can always keep an eye out...
nictesla is offline
post #8 of 8 Old 04-14-2019, 07:15 PM
J-Strom 2019's Avatar
lowering
Hi.
I just purchased a 2019 650XT touring. After reading this thread I just installed the Adventure Tech lowering links (1 1/8"). It has been to cold to ride. Looking forward to see how it handles. The angle with the kick stand down did not change much (1/4" measured from foot peg to ground). With watching how I park I think it will be ok not shortening the kick stand. I did not lower the forks.
J-Strom 2019 is offline
Bypass Side Stand Switch? Juan_Banjovy DL650 and DL650A - 2004 to 2011 24 01-30-2019 09:51 AM
Chain Slack with Raising Lowering Links richlandrick General V-Strom Discussion 0 08-14-2015 10:19 AM
Problem with Soupy's adjustable side stand TheCowGod DL650A - 2012-2016 4 04-19-2014 11:38 PM
