Question for those who've installed risers without modification - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 7Likes
post #11 of 23 Old 04-06-2019, 01:41 PM
Originally Posted by rooster shooter View Post
You also dropped the front end which makes a huge difference.
This doesn't make any difference.
Sliding the forks up in the triple tree doesn't change the distance the upper brake line travels from the master cylinder to its destination just above the radiator.
Lowering does, however, shorten the length needed for the lower brake line that runs from above the radiator to the right caliper. But, no need to buy shorter lines. Stock length works fine. You'll just have some extra slack.
brock29609 is offline
post #12 of 23 Old 04-08-2019, 07:41 PM
rooster shooter's Avatar
I think I've read that before, goes against conventional wisdom tho.
'13 GL1800
'17 DL650A
rooster shooter is offline
post #13 of 23 Old 04-10-2019, 11:02 AM
Always better to be a bit longer than too short....IJS
badjuju is offline
post #14 of 23 Old 05-08-2019, 08:04 PM
I bought the same ones that Hogges bought on eBay. The install was a breeze and it corrected the handle bar reach that my Corbin seat had caused. Absolutely worth the small cost.
Sent from my SM-G950U using Tapatalk
Dubldee17 likes this.
hb9400 is offline
post #15 of 23 Old 05-09-2019, 09:04 PM
...goes against conventional wisdom tho.
Brake lines on many bikes (w/o ABS) go from the master cylinder down to the caliper. In those cases, sliding the forks up does add to brake line slack because you're moving the master cylinder closer to the caliper. This is not at all the case on our bikes.
post #16 of 23 Old 05-10-2019, 10:34 AM
I got 2 pair from a fellow member. One is up 1" and the other set is actually sold for a 1200 GS BMW and comes up an inch and back an inch.
Installed on an '04 and an '05 650, not need for cable fiddling but they are about at the extreme of slack.
I can't see the maker marks and I forget what it was.
post #17 of 23 Old 05-11-2019, 09:15 PM
Josh's Avatar
Went up an inch with these. 40 bucks in Australia local bike shop. No adjustments or replacement parts required
File Type: jpg 15576232902825934360866675473632_1557623311531.jpg (393.4 KB, 20 views)
Josh is offline
post #18 of 23 Old 05-19-2019, 10:27 AM
Li432Paul's Avatar
Do you have the sellers info from ebay?
2018 DL650AXT Mods
Corbin Seat
Garmin Zumo 396LMTS GPS
Cardo Bold JBL Comm.
SW Motech Crash Bars
Denali DR-1 Led Lights
IMS Adventure 1 Pegs
SW Motech EVO Tank Bags Micro, Engage
GIVI V47 Top Case
GIVI Skid Plate
OEM Center Stand
Zeta offset Risers
MZS Levers
Adventure Tech Mirror Extenders, Kick Stand Plate and Peg Lowering Kit
Helmet Guardian
Fenda Extenda
National Cycle V-Stream 19 inch Shield
ZETA Armor Hand guards
Li432Paul is offline
post #19 of 23 Old 05-19-2019, 12:59 PM
I have an old pair of rox risers. spent all afternoon trying to get them into the system and without mods I would not have enough play for my conservative tastes. Bought some risers that went up about 1 inch and back about 1 inch. they fit and worked good but with the stock seat I was sitting absolutely bolt upright. Went with 30 mm risers and they work and fit me best, I like to lean forward just a little bit when riding. YMMV.
RLBranson is offline
post #20 of 23 Old 05-19-2019, 06:27 PM
I also bought and installed the ones from Turkey. They worked as the others stated, and made the bike much nicer to ride IMO. I left my front brake line anchor loose and will fab a bracket to fix it back. Also moved throttle cables to the rear of the top clamp. The cables are only just long enough. I would prefer them a couple inches longer but I've seen no problems with them as they are.
The ebay item number is 262890691963. Mine arrived in the time promised, and tracking was somewhat accurate. I got a couple of the Suzuki plastic caps for the hex bolt sockets and it looks very original. I'm surprised how much more comfortable it made my bike. DD
hb9400 likes this.
Dubldee17 is offline
Installed distribution block - quick question about wire tie in Strider1520 DL650 and DL650A - 2004 to 2011 6 01-12-2012 03:09 PM
Installed ROX Risers. Big_tone Australia-New Zealand 6 07-20-2011 09:14 PM
First Look: ROX¯s NEW Pro-Offset Elite block risers Mercenary V-Strom Modifications and Performance 17 10-06-2010 10:37 PM
Has anyone installed the ABS extension brake line for the Rox Risers Al Gilliland General V-Strom Discussion 1 02-16-2010 08:57 PM
A question for thoses who installed the plasmaled 3 watt led lights Al Gilliland General V-Strom Discussion 4 01-11-2010 10:12 PM
