Givi crash bar vibration fix - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 7Likes
  • 7 Post By Lasher
post #1 of 6 Old 04-03-2019, 02:51 PM Thread Starter
I've had the givi crash bars on my bike for a year now. They have always had a horrendous vibration from 5k to 5.4k. I've tightened, re tightened and reinstalled with no effect. A few weeks ago I was determined to fix it.
I had read about hanging weights but the bike is already under powered with the weight it has. I thought there has to be a better solution and then it hit me. What do they do they use on cars, especially between body panels? Foam. So I filled them with expanding foam. It's been a few weeks now and the vibration is gone. The bike is as quiet as when I first got it now with very little weight added to fix the issue. Hope it helps somebody out there.
If you try this coat the outside of the bars with WD40 first. It will make cleanup a lot easier.
Dread7, fbarbas, notacop and 4 others like this.
Lasher is offline
post #2 of 6 Old 06-01-2019, 08:45 AM
it's work !! Thank you
nimes is offline
post #3 of 6 Old 06-01-2019, 11:44 AM
Me next!!!
I'll report back after I get around to doing this mod on my machine!
gdrew is offline
post #4 of 6 Old 06-01-2019, 11:49 AM
What are you putting the foam in or on? Body panels?
RLBranson is online now
post #5 of 6 Old 06-01-2019, 11:56 AM
PerazziMx14's Avatar
They are filling the inside of the crash bar tubes with expanding foam aka "Great Stuff".
PerazziMx14 is online now
post #6 of 6 Old 06-01-2019, 12:40 PM
Just FYI, as a DIY landlord of several rental homes I think the Loc-Tite expanding foam seems more dense and flexible and better for this job than the Great Stuff stuff. The Great Stuff seems more brittle and maybe more likely to break down from vibes.
This stuff, specifically...
brock29609 is offline
GIVI Airflow Windscreen, V35 Side Cases, V47 Top Case and More (2017 V-Strom XT) uclakoolman DL650A - 2017+ 8 06-29-2018 09:18 AM
Compatible skid plates for Givi Crash bars Midwinter DL1000A - 2014-2016 2 06-22-2017 01:13 AM
Givi Crash Bar Vibration at a certain RPM jammaj V-Strom Modifications and Performance 63 08-04-2012 04:06 PM
Crash Bars/Skid Plates- Q&A - all you could ask and then some Skinnifatkid General V-Strom Discussion 11 05-29-2010 12:46 PM
