Seeking advice on crash bars, skid, center-stand setup - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
post #1 of 16 Old 03-20-2019, 04:00 PM Thread Starter
Martin's Avatar
Hello,
I'm seeking advice/feedback on the following proposed configuration for my new 2019 650x...
Happy Trails skid plate
SW Motech center stand
OEM, Givi or SW Motech crash bars (these are listed at the HT site as compatible with the HT skid plate)
Thanks,
MV
2019 650X
Martin is offline
post #2 of 16 Old 03-20-2019, 04:26 PM
Location: Ann Arbor, MI and San Miguel de Allende, Mexico
On my 2018 1000 txt, the OEM center stand, crash bars, and Happy Trails skid plate all play well together. Youíll need to support the bike without the stands as the skid plate uses those mounts, IRC. I used ratchet straps to the tracks to the garage overhead door. Youíre just keeping the bike vertical so there isnít much weight on the straps.
I donít know about the Motech stand but the OEM works well.
Vinnie
Currenv is offline
post #3 of 16 Old 03-20-2019, 05:25 PM
Congrats on the new ride!
My 2018 XT set-up is:
SW Motech Crash Bars
OEM Center Stand
Happy Trails Skid Plate
and they all work well together.
George
2018 Vstrom 650 XT
ProTaper ATV Mid 1 1/8 inch Bars
ProTaper Conversion Risers
Happy Trail Skid Plate
AdventureTech - Foot peg Lowering kit
AdventureTech - Dash GPS Mount
AdventureTech - Rear Rack
georgej is offline
post #4 of 16 Old 03-21-2019, 10:17 AM Thread Starter
Martin's Avatar
Vinnie
OK thanks. I have a chain hoist in the garage so suspending the bike upright won't be a problem.
- Martin
2019 650X
Martin is offline
post #5 of 16 Old 03-21-2019, 10:21 AM Thread Starter
Martin's Avatar
OEM Center Stand
George
Thanks. I went with the SW-SW-HT combo. HT verified that the skid plate works OK with the SW Motech stand. I have the SW-M stand on my 2005 and like it.
- Martin
2019 650X
Martin is offline
post #6 of 16 Old 04-13-2019, 10:21 AM Thread Starter
Martin's Avatar
OEM Center Stand
George
I had some trouble getting the HT front bracket mounted to the SW-M cross bar... the holes in the bracket did not line up at all with the SW-M screws. It looks like SW-M might have changed the way the cross-bar connects (the HT instructions show the old-style SW-M cross bar I remember from my 2005 setup).
I drilled a couple of new holes into the bracket to line up with the SW-M screws and that worked.
This is how the "new" SW-M setup looks...
2019 650X
Martin is offline
post #7 of 16 Old 04-13-2019, 10:43 AM
Congrats on the New 2019!
Bob S.
2017 Vstrom 650 Base model (White)
2017 Yamaha YZ250X
Previous loves:
1982 Yamaha 650 Seca
1978 Honda CB550
1975 Suzuki GT380
1977 Yamaha RD400
1973 Can Am MX1 125
Nicad is offline
post #8 of 16 Old 04-13-2019, 11:53 AM
Not sure I follow you - No drilling required here - The way my HT skid plate mounts to the cross bar of the crash bar is with a nicely lined u-clamp provided by HT - I ended flipping the mount (behind the bar instead of in front of the bar as indicated in the instructions) so I got the plate to fit closer to the motor.
I may drill the skid plate to utilize the bottom holes of the bracket hardware (you can see what I'm referring to in the picture).
George
2018 Vstrom 650 XT
georgej is offline
post #9 of 16 Old 04-13-2019, 01:09 PM Thread Starter
Martin's Avatar
Wow, mine looks nothing like that! No U-clamps. Looks like they sent me the previous version of the mount kit for SW-Motech. I'll contact them for clarification.
2019 650X
Martin is offline
post #10 of 16 Old 04-14-2019, 11:11 AM Thread Starter
Martin's Avatar
I think I found the problem... there is this fine print down below at the HT web page for the DL 650...
** If your SW Motech crash bar has the center clamp you need the MK-3 mount kit. If you have the bolt together type, you will need the MK-2 mount kit. **
I have the newer bolt-together type. So, evidently, I was supposed to order the MK-2 mount kit for "OEM" crash bars... and NOT the MK-3 "SW-Motech" kit... for the SW-Motech bars which I have on the bike? That's crazy.
I'm working with someone in customer support at HT to get this resolved but they really need to fix their website or someone else is bound to run into the same issue.
-MV
2019 650X
Martin is offline
Ravetech Skid Plate + T-Rex Racing Crash Bars on 2017 650 DavidDavid DL650A - 2017+ 1 09-19-2018 01:47 AM
Heed crash bars and skid plate beufort V-Strom Modifications and Performance 23 07-04-2017 03:33 PM
The Urban Jungle - why we need skid plates and crash bars KZDon Maintenance, Tech and Products. 0 08-12-2015 02:11 PM
enduro guardian skid plate with so motech crash bars work! ukele6 DL650 and DL650A - 2004 to 2011 4 10-15-2014 10:39 AM
Skid Plates for Vstrom and GIvi Crash Bars willorge DL650 and DL650A - 2004 to 2011 15 03-21-2014 06:22 PM
