Adding Hazard Flashers - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 1 Post By brock29609
  • 1 Post By BackPacker
post #1 of 3 Old 03-17-2019, 11:39 PM Thread Starter
Question Adding Hazard Flashers
hey. Just got a new 650XT in California. Horrified to see that it doesn't come with Hazard lights (4 way flashers). It seems I should be able to short the left and right wires coming out of turn signals together via a switch and two diodes to re-create the missing function. I've searched this forum and no one seems to have done it. Why not? What am I missing?
mozzer502 is offline
post #2 of 3 Old 03-18-2019, 09:22 AM
I do recall someone mentioning here that they had done just that, with a switch added to body work that when turned on would cause the flashers to blink on both sides when activated for either side. Not a difficult wiring job at all. Go for it!
mozzer502 likes this.
brock29609 is offline
post #3 of 3 Old 03-18-2019, 09:47 AM
It's probably much easier to buy the left handlebar cluster from a similar-year but EU-spec 650. All EU-spec bikes have the hazards by default. You can either get a new one from the usual sources, or try to get a 2nd hand one from one that was in an accident and written off. It's also a much cleaner solution that way.
The other thing to be aware of is that you might need another relay to deal with the higher current, if your current relay is not designed to handle both the 2-way and 4-way current. However, information about whether this is required is hard to come by. Best is to look at your current relay (just in front of the battery) and see if it has something like ("T: 21Wx2" and "H: 21Wx4") on it. The T is the wattage of 2-way flashers (normal indicators) and the H is the wattage of all four flashers combined.
BackPacker is offline
Hazard light on 2017+ DL650? Kankujoe DL650A - 2017+ 3 01-07-2019 08:53 PM
Flashers won't turn off BigLar75 DL650 and DL650A - 2004 to 2011 2 12-01-2017 01:13 PM
Adding Hazard Lights to 2002 Vee maz_norcal General V-Strom Discussion 3 08-11-2014 12:48 AM
4 way flashers nuke Feedback to Suzuki 3 09-29-2013 09:42 AM
Installing Buell Flashers NordStrom DL650 and DL650A - 2004 to 2011 24 10-28-2010 07:50 AM
