Figuring out givi luggage - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By KSM
post #1 of 8 Old 03-12-2019, 02:30 PM Thread Starter
TinyBear's Avatar
What rack am I going to need to mount this https://fortnine.ca/en/givi-obk42-tr...nokey-top-case top box on my 2017 Vstrom 650xt than has the factory side bags?
2017 Suzuki V-Strom 650 XTSE
2010 Yamaha TW200
2016 Polaris Sportsman 450HO
2004 Suzuki Ozark 250
TinyBear is offline
post #2 of 8 Old 03-13-2019, 10:56 AM
I recommend SRA3112 which is the thin gray metal rack, but another option is SR3112 + one of their separate ugly plastic mounting plates (M5 or M7).
You may have to buy two longer bolts to make either of these options work with that OEM side cases. That discussion has happened *HERE*.
brock29609 is offline
post #3 of 8 Old 03-13-2019, 11:17 AM Thread Starter
TinyBear's Avatar
Awesome thanks for the assistance.
2010 Yamaha TW200
TinyBear is offline
post #4 of 8 Old 03-13-2019, 04:17 PM
Umbrianissimo's Avatar
@TinyBear
The SR3112 is a support system for the factory rear rack, which is a composite. The extra support for the factory rack very likely increases it's strength. I've seen a broken rack. Then, you add a mounting plate for your particular box. Givi monoKEY boxes have different plates than monoLOCK boxes. The M5 & M6 plates are for monolock boxes. I believe, but I am not absolutely certain, that monokey plates are specific to certain monokey boxes, so you need to get the correct plate. Mono lock and mono key plates both bolt to the SR 3112 support and horizontal, flat mounting rails.
I just did this install on the weekend, and I also have the factory side cases and it all fits nicely. See other thread about need for two longer bolts to go through the OEM side case body mounting rails. Hope I did that correctly.
https://www.stromtrooper.com/dl650a-...-max-load.html
Damon
2017 DL 650 and maybe another Vespa?
I'm having an adventure- so, its an adventure bike.
Now that summer is here, I'm retiring so I can ride full time.
Umbrianissimo is offline
post #5 of 8 Old 03-14-2019, 09:50 AM
Originally Posted by Umbrianissimo View Post
@TinyBear
The SRA3112 comes with all the same support hardware as the SR3112, and includes a more-attractive gray aluminum rack so you don't have to buy the M5 or M7 plastic rack separately. Here it is...
post #6 of 8 Old 03-16-2019, 10:08 AM
Great GAK. That box costs more than I paid for my 05 Wee!
I hope it's bulletproof.
post #7 of 8 Old 03-16-2019, 10:57 AM
KSM
KSM's Avatar
@TinyBear if you haven't ordered this stuff already price it out at motostorm.it you might save a bundle.
brock29609 likes this.
2012 DL650A (purchased Dec 2017)
2005 DRZ400S (sold Dec 2017)
1972 Norton Commando (sold 1984)
1978 Suzuki DR370 (sold 1982)
KSM is offline
post #8 of 8 Old 03-16-2019, 02:17 PM
Hi
I have the SRA3112 on my VStrom 650 XT (2018) witch the Givi trekker outback top case 42l and I have make more than 6000 km with no problem,
The product quality is good
juve is offline
Adventure Tech's Adapter for Givi top box on a DL650 Adventure luggage rack KevinP Product Reviews 1 09-28-2016 05:17 PM
Do all GIVI luggage products require key to open? (Open to recommendations top cases) Pushrod DL1000A - 2014-2016 2 08-14-2016 04:55 PM
removing scratches from Givi luggage, after a drop Dakar General V-Strom Discussion 5 02-25-2016 10:33 PM
