Installed the Givi skid plate - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 1 Post By Li432Paul
  • 1 Post By GreyMotion
post #1 of 7 Old 03-05-2019, 05:47 PM Thread Starter
Li432Paul's Avatar
Installed the givi skid plate lastnight. Straight forward install not too bad. It is a light weight plate not for heavy off road riding. But I'm happy with it so far. Bought it from a forum member.
georgej likes this.
2018 DL650AXT Mods
Corbin Seat
Garmin Zumo 396LMTS GPS
Cardo Bold JBL Comm.
SW Motech Crash Bars
Denali DR-1 Led Lights
IMS Adventure 1 Pegs
SW Motech EVO Tank Bags Micro, Engage
GIVI V47 Top Case
GIVI Skid Plate
OEM Center Stand
Zeta offset Risers
MZS Levers
Adventure Tech Mirror Extenders, Kick Stand Plate and Peg Lowering Kit
Helmet Guardian
Fenda Extenda
National Cycle V-Stream 19 inch Shield
ZETA Armor Hand guards
Li432Paul is offline
post #2 of 7 Old 03-05-2019, 06:18 PM
Manitoba's Avatar
Looks very nice! Need to get me one this year.
Manitoba is offline
post #3 of 7 Old 03-05-2019, 06:34 PM
Thinking of doing the same.How much of a PTA when changing the oil?
OLDhippy88 is offline
post #4 of 7 Old 03-05-2019, 07:47 PM
GreyMotion's Avatar
The bottom 4 screws need to come out. With that said, the four rubber washers that fit between the bottom brackets and the top side of the skid plate are a big PITA when putting back together. Also, be careful because some of the washers stick to the plate (A good thing) and others fall out and roll around the floor. I also usually take the top front screws off as well and clean everything up. (Basically, I remove the plate)
I'm pretty happy with my plate as it is pitted pretty good from rocks-so it's doing its job.
Li432Paul likes this.
GreyMotion is offline
post #5 of 7 Old 03-09-2019, 07:41 PM
Martin's Avatar
Is it strong enough to support the bike... i.e. on an ATV-type jack? I'm guessing no, but that is probably not an intended use.
- Martin
2019 650X
Martin is offline
post #6 of 7 Old 03-10-2019, 12:28 AM
It comes of pretty easy, but like GreyMotion said, the little rubber grommets between the side plate and bracket are a pain to get lined up right. I fixed this last time by just super gluing them in place and let it dry while I changed the oil.
PDX_Strom_Trooper is offline
post #7 of 7 Old 03-10-2019, 12:29 AM
- Martin
Yeah, I would not trust it for that at all. The aluminum might hold up, but the brackets would surely bend out of shape.
Hepco & Becker skid plate (Sump guard) and Givi Engine Guards disassembled DL1000A - 2014-2016 12 07-14-2015 09:04 PM
Givi Skid Plate Fitment pjmarkham DL650A - 2012-2016 5 12-23-2013 07:48 AM
Murphs Kit Center Stand + Givi Crash Bars + SW Motech skid plate: Success NewButOld DL650 and DL650A - 2004 to 2011 0 02-10-2013 09:01 PM
