Monokey topcase with OEAM panniers - OEM rear rack max load - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 9Likes
post #1 of 31 Old 02-25-2019, 06:44 AM Thread Starter
Hello,
Could some 2017+ givi 650 owner can confirm whether is possible to have monokey givi topcase with OEM panniers?
I ask that because givi SR3112 system has some tubular "pipe" (one each side) that does connection between the givi plate (on rear rack) and some frame mount below the seat.
This frame mount is used to install OEM rack for side cases.
Through the web I have seen similar installation... for the vstrom 1000. Although 650 and 1000 rears look very similar, the reference of givi mounting rack is different.
Besides could some 2017+650 owners tell about the max load rating for OEM rear rack (maybe displayed on a sticker or user manual)
It would help me choose between givi v47 and trekker 52 (9.72 vs 11.44 lbs according to giviusa.com)?
Thanks a lot.
andrep is offline
post #2 of 31 Old 02-25-2019, 11:14 AM
Looking at the installation instructions for the Givi hardware and pics of the OEM case brackets, they'll work together. The Givi brackets come with a longer bolt that allows the support brackets to attach on the back side of the side case mounts (under the tail section, over the wheel). No interference between the two.
Funny that Givi sees the need to add these extra support arms when the OEM top case mount doesn't have it.
andrep likes this.
brock29609 is offline
post #3 of 31 Old 02-25-2019, 01:55 PM Thread Starter
Thanks for four feedback brock29609!
To my opinion the purpose is to spread the weight to rear rack and frame in case rider use big topcase. OEM is 35L so I think it is lighter than any monokey topcase with 40L capacity so rear rack may be sufficient.
andrep is offline
post #4 of 31 Old 02-25-2019, 07:40 PM
branthopolis's Avatar
Not sure about the 650, but if the tail section is similar to the 1000 (?) than it should.. I've got a 2015 Vee2 here with the Givi topcase mount (that has the sidearm supports) worked fine with the OEM side bags and with my current Bumot sidebag setup.. Worked fine with both the E460 and with the TRK52...
Here's a thread I started back when I did the install..
https://www.stromtrooper.com/dl1000a...side-bags.html
andrep likes this.
~Mark
2015 DL1000A
2005 YZ250
branthopolis is offline
post #5 of 31 Old 02-25-2019, 07:47 PM
Givi still quotes, I believe, a 25 lb limit for carrying capacity, but the rear plate is definitely MUCH better supported and I can only imagine FAR less likely to break when the load/full topcase bounces on bumps... I'm thinking I remember that there were actually a few broken racks early on from people overloading them and later finding them cracked.......
~Mark
2015 DL1000A
2005 YZ250
post #6 of 31 Old 02-26-2019, 03:21 AM Thread Starter
Thank you branthopolis. Very helpful thread you created.
andrep is offline
post #7 of 31 Old 02-26-2019, 05:16 AM
Li432Paul's Avatar
Givi rack installed
andrep likes this.
2018 DL650AXT Mods
Corbin Seat
Garmin Zumo 396LMTS GPS
Cardo Bold JBL Comm.
SW Motech Crash Bars
Denali DR-1 Led Lights
IMS Adventure 1 Pegs
SW Motech EVO Tank Bags Micro, Engage
GIVI V47 Top Case
GIVI Skid Plate
OEM Center Stand
Zeta offset Risers
MZS Levers
Adventure Tech Mirror Extenders, Kick Stand Plate and Peg Lowering Kit
Helmet Guardian
Fenda Extenda
National Cycle V-Stream 19 inch Shield
ZETA Armor Hand guards
Li432Paul is offline
post #8 of 31 Old 02-26-2019, 05:17 AM
Li432Paul's Avatar
givi v47 top case
andrep likes this.
2018 DL650AXT Mods
Corbin Seat
GIVI V47 Top Case
GIVI Skid Plate
OEM Center Stand
Zeta offset Risers
MZS Levers
Helmet Guardian
Fenda Extenda
post #9 of 31 Old 02-26-2019, 05:58 AM Thread Starter
Thanks for these picture Li432Paul. It helps seeing how v47 looks like on a 650.
andrep is offline
post #10 of 31 Old 02-26-2019, 09:31 AM
Consider the version with the silver panel and smoked lenses. Fits the look of my white/gray/black bike very well. Looks OEM.
rear rack support bracket gtmn DL1000A - 2014-2016 6 12-28-2015 03:33 PM
possibly a stupid rear rack question adventure nurse General V-Strom Discussion 5 01-25-2014 10:29 PM
