Raising links? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 18Likes
post #1 of 32 Old 02-24-2019, 10:16 PM Thread Starter
WingVetteStrom's Avatar
Raising links?
I want to achieve about another inch more of ground clearance under the skid plate. Thinking about raising links. Anyone done this?
Although I lowered my seat as I only have a 30" inseam, so I'd have to figure out how to get the/a new seat back down an inch?
2018 V-Strom 650XT
2018 Goldwing Tour DCT
2015 Z51 Corvette Stingray
WingVetteStrom is offline
post #2 of 32 Old 02-25-2019, 12:06 AM
Rolex's Avatar
I lifted the back of my Wee by 1", I was not after more ground clearance I just wanted the bike to steer quicker that is why I left the front down 10mm.
To me it made my Wee the perfect bike.
I would love to do my V2 but my legs are not long enough for the wider ride.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #3 of 32 Old 02-25-2019, 08:54 AM
Motor7's Avatar
36" inseam here and went with 3/4" raising links....wish I had gone to the 1.5". Keep in mind much over 3/4-1" will require modding the kickstand and center-stand length.
WingVetteStrom likes this.
'15 DL650XT
Motor7 is offline
post #4 of 32 Old 03-01-2019, 12:24 PM
cyclopathic's Avatar
Get Soupy rising links. Soupy has 2 versions lowering and rising. Lowering allow adjustment in 0 to -4" and rising in +/-2" range good luck.
cyclopathic is offline
post #5 of 32 Old 03-01-2019, 12:27 PM
And hydraulic jack to push off kickstand if you parked on the slop :hide
Motor7 likes this.
post #6 of 32 Old 03-01-2019, 01:04 PM
Stromtrooper.com Sponsor
richlandrick's Avatar
We have raising and lowering links and lots of people on Stromtrooper have experience with our links.
https://www.adventuretech.biz/gen-1-...-1-dl1000.html
Big B and TheSexyMedic like this.
richlandrick is offline
post #7 of 32 Old 03-01-2019, 03:16 PM Thread Starter
But it did raise your skid plate ground clearance by 1" correct?
2018 V-Strom 650XT
post #8 of 32 Old 03-01-2019, 03:29 PM Thread Starter
Sent you an email Rick.
2018 V-Strom 650XT
post #9 of 32 Old 03-02-2019, 09:34 AM
If you raise just the rear (over the hub) 1", you'll lift the midpoint between the hubs a half inch, right? The front edge of the skid plate will be raised even less than that.
richlandrick and Motor7 like this.
brock29609 is offline
post #10 of 32 Old 03-02-2019, 10:25 AM
I see no point in the "rear" raising links if the front cannot be raised the same, lowering both ends is the easy solution. That is going to change the rake of the bike, will raise part of the engine case higher in the rear section and lower in the front section.
Raising and Lowering Links richlandrick AdventureTech LLC 66 03-03-2019 11:36 AM
Raising Links, Sag, Dampening JorgeLuis V-Strom Service and Maintenance Questions and Discussions 16 02-24-2019 10:22 AM
Raising Links, Sag, dampening JorgeLuis DL650A - 2012-2016 1 02-18-2019 06:59 PM
Chain Slack with Raising Lowering Links richlandrick General V-Strom Discussion 0 08-14-2015 10:19 AM
Just installed AdventureTech's raising links - with pics Shag DL650A - 2012-2016 6 04-19-2014 01:31 AM
