Oxford grips. Use caution - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 11Likes
post #1 of 15 Old 02-22-2019, 01:45 AM Thread Starter
WingVetteStrom's Avatar
I installed the Oxford grips, and they work great, however use caution. Towards the end of a 6300 mile trip from here in the Seattle area through Mainland Mexico and Baja the bike stopped being able to start in gear. With the clutch pulled in obviously. I'm not positive yet, but I'm pretty sure the problem was the Oxford grips are thicker than the OEM grips, and maybe even thicker when they're on full heat. I think what happened is the clutch switch plunger because the clutch lever couldn't be pulled in all the way wasn't extending fully, so the starter circuit remained open. Solution is to either cut a small piece off the end of the plunger, or file down a little bit of area on the clutch handle right where the plunger hits it.
notacop and DesertBike like this.
2018 V-Strom 650XT
2018 Goldwing Tour DCT
2015 Z51 Corvette Stingray
WingVetteStrom is offline
post #2 of 15 Old 02-22-2019, 06:12 AM
Rolex's Avatar
That is the first I have heard of that, I know of many Stroms with grip puppies fitted over their oxford grips and they have no issue.
Have you had a good look at your switch to ensure it is seated properly and are you using a Suzuki leaver ?
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #3 of 15 Old 02-22-2019, 07:05 AM
Mucksavage's Avatar
@WingVetteStrom , what @Rolex said....I have heated grips & Grip Puppies used together with no troubles that you have indicated.
'12 Glee, Metallic Fox Orange, '98 DR350, CMA #183680
Mucksavage is offline
post #4 of 15 Old 02-22-2019, 09:02 AM
Onboard Mass Damper
DesertBike's Avatar
Can we all just take a moment to appreciate how luxurious that sounds?
I was planning to put Oxfords on for next winter anyway, might have to Do Both!
DesertBike is offline
post #5 of 15 Old 02-22-2019, 09:11 AM
I have both....awesome.
DesertBike likes this.
Hatchi is offline
post #6 of 15 Old 02-22-2019, 10:16 AM
What happens, is that the wiring hump as I like to call it, can interfere with the clutch actuation due to the grip rotating. I have never had "3" installs of Oxfords rotate or cause a single issue for me, of course I glue them quite well on the clutch side. Oh....I've also run grip puppies over my Oxfords as well with zero issues.
post #7 of 15 Old 02-22-2019, 10:51 AM
Grip rotation happened to me too. I still have crunchy shifts.
post #8 of 15 Old 02-22-2019, 06:42 PM
America First's Avatar
Grip puppies??? I'm going to have to look that up. Never heard of that before.
Ah, ok. Google to the rescue once again. They are foam grips to cover your existing grips.
2017 DL650 (white)
America First is offline
post #9 of 15 Old 02-25-2019, 09:17 AM
Motor7's Avatar
I actually need to replace my grip puppies over my oxfords.....wore thru the left hand one that is now starting a tear. Going on their third year.........
'15 DL650XT
Motor7 is offline
post #10 of 15 Old 02-25-2019, 09:31 AM
Oxford + grip puppies here as well. No issues.
BigTK is offline
Oxford Heaterz heated grips install report V-Strom Ry Maintenance, Tech and Products. 3 10-21-2014 08:01 PM
Oxford "Hot Hands" Heated Grip Wraps Warhammer Product Reviews 7 12-21-2013 09:06 PM
Wiring Oxford heated grips to First Gear controller Borghi DL650 and DL650A - 2004 to 2011 7 09-23-2013 06:15 PM
Oxford grips alternate switch replacement Uncle Fester DL650A - 2012-2016 2 09-01-2013 01:22 PM
Oxford Heaterz Grips CarbideDude General V-Strom Discussion 17 04-11-2008 08:39 AM
