Headlight Modulator - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
  • 4 Post By Trepidator
post #1 of 8 Old 02-01-2019, 12:37 PM Thread Starter
Location: San Jose, California, USA, North America, Earth
Headlight Modulator
Seem that no company make the headlight modulator for H9, high beam bulb. Any idea / suggest? The drivers are glued to their cells during traffic jams in SF Bay Area.
TaubBaer is offline
post #2 of 8 Old 02-01-2019, 01:16 PM
Lightbulb
Three suggestions:
1. Wear Hi-Viz gear, especially the helmet. (This reduced violations of my right-of-way by 3X.)
2. Set your speed so that the time when you can avoid an incursion into your trajectory by stopping overlaps the time when accelerating will work. Be aware of where/when the two zones end and begin so that you can respond quickly. [a]
3. Learn about the weave [b] and use it when approaching potential right-of-way violators who could hurt you. I have seen this to work well.
[a. And when you must evade by slowing/stopping or accelerating, review your assessment of what you had thought workable. Adjust if needed. ]
[b. See V-Tom's posts (in his signature) for links to sites explaining "the weave". ]
Big B, V-Tom, VSrider and 1 others like this.
Trepidator is offline
post #3 of 8 Old 02-01-2019, 03:53 PM
larolco's Avatar
Eastern Beaver is good stuff.
Not H9 specific, but maybe this would work: https://easternbeaver.com/Main/Wirin...H4/non-h4.html
DRZ400SK17
larolco is offline
post #4 of 8 Old 02-10-2019, 08:02 PM Thread Starter
Finally installed the Kisan Headlight Modulator today! Hope it is worth my $$$. I had to remove the dashboard and some trims to access the bulb and tie up the device. Suzuki needs to redesign the dashboard so it will be easy to reach in and replace the bulbs!
TaubBaer is offline
post #5 of 8 Old 02-12-2019, 04:58 PM
kisantech has them
search on
P115W-DHL
then specify H9/H7
its listed for Triumph but is what you want. I have it installed on my 2018 and I really like that I can just switch to low beam if I want to defeat the flashing.
Larry
slocool is offline
post #6 of 8 Old 02-12-2019, 05:37 PM
iamsmiling's Avatar
Kisan Electronics makes a H9 adaptor you can order.
https://kisantech.com/pa-h9.html
iamsmiling is offline
post #7 of 8 Old 02-13-2019, 03:40 PM Thread Starter
I got this model: https://kisantech.com/p115w-a2.html
TaubBaer is offline
post #8 of 8 Old 02-13-2019, 04:20 PM
iamsmiling's Avatar
I've had very good luck with mine. It has been on two Stroms for a decade and works fine. I have an earlier version of the P115W-S-D
LED headlight with headlight modulator ThinkingOfOne DL1000 from 2002-2012 4 10-22-2017 09:11 AM
Headlight Modulator on Vstrom. Adding a dashboard indicator. FredBGG DL1000 from 2002-2012 0 01-03-2015 11:14 PM
Headlight modulator installation tutorial, Photo illustrmond Star Modulator)ated (Dia zaxizax Maintenance, Tech and Products. 15 04-08-2012 03:16 AM
Quick headlight modulator questions... ediggity Maintenance, Tech and Products. 6 06-18-2010 05:56 AM
If you have a Diamond Star headlight modulator this is a must read! Ruggybuggy General V-Strom Discussion 19 06-24-2008 12:46 AM
