change low beam bulb? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
  • 2 Post By brock29609
  • 1 Post By blaustrom
post #1 of 7 Old 01-22-2019, 10:35 PM Thread Starter
slipstream's Avatar
how hard is it to change the low beam bulb...or maybe a better question...how long should it take someone who has done it before?
tia
BOYCOTT Photobucket!
slipstream is offline
post #2 of 7 Old 01-23-2019, 06:38 AM
I haven't done it, but you have to remove the dash instruments. I think it is straightforward after that.
Bob S.
2017 Vstrom 650 Base model (White)
2017 Yamaha YZ250X (Sold)....Hopefully WR250R soon
Previous loves:
1982 Yamaha 650 Seca
1978 Honda CB550
1975 Suzuki GT380
1977 Yamaha RD400
1973 Can Am MX1 125 (bought while Mom out of town)
Nicad is offline
post #3 of 7 Old 01-23-2019, 10:20 AM
Your manual has good instructions for removing the front body panels. Do that, then remove the dash. The bulbs are behind the dash. Not rocket surgery.
Having done it before it would take me 20 minutes, but if you're not an experienced wrencher allow yourself 2 hours and don't rush it. It probably won't take nearly that long.
DesertBike and slipstream like this.
brock29609 is offline
post #4 of 7 Old 01-23-2019, 10:49 AM Thread Starter
slipstream's Avatar
thanks . !
post #5 of 7 Old 01-23-2019, 01:16 PM
blaustrom's Avatar
If it is similar to the V2 then it's 2 screws and 2 plastic rivets if I remember right, then unhook the instrument panel and power socket and the panel comes free. Then you have access to both bulbs. Once you know how it's done it takes probably less than 10 minutes to change the bulb. No need to remove any of the other panels.
Doesn't the owners manual outline what needs done to change the bulb?
NVDucati likes this.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #6 of 7 Old 01-23-2019, 04:51 PM
Unfortunately, it's not that easy. I'm looking at the service manual and the first two steps are...
  • Remove the front side covers
  • Remove the fuel tank front cover
These have to be off to access side screws that are holding the dash on.
post #7 of 7 Old 01-23-2019, 08:11 PM
blaustrom's Avatar
OK, good to know that the 650 and 1000 are that different. And I thought already that changing the bulb for the V2 is a pita …
Blau2 2014 DL1000A
Hi beam Cut Adapter JorgeLuis Maintenance, Tech and Products. 4 08-10-2018 05:21 PM
Little peanut bulb under the high beam? Jimmy650 DL650A - 2017+ 3 05-03-2018 10:41 AM
$110/tire for labor to change tires? Is this a joke? JoshS General V-Strom Discussion 51 06-19-2016 09:57 PM
New Filter with Every Oil Change? Merlin General V-Strom Discussion 38 09-02-2012 06:47 PM
