Plug for rear brake light flasher? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 01-13-2019, 11:25 AM Thread Starter
I'm looking to install a rear brake light modulator I got for Christmas but don't know what plug I need to use. I got a plug and play kit from Vizi-tec but they weren't sure if the connectors had changed on the 2017 650's. From my quick glance I don't see a plug resembling the one thats on my brake light modulator and the adapter that's on the eastern beaver website looks different as well. I don't store my bike at my house and its been pretty cold so I haven't had a chance to really dig into the bike. Does anyone know for sure where on the bike the plug I would need is located and what the connector looks like?
Thanks
(the one on the left looks different than the plugs on my vizi-tec kit)
https://easternbeaver.com/Main/Bike_...ewdls.html#bta
2017 DL650
YJGUY is offline
post #2 of 10 Old 01-13-2019, 11:57 AM
I just installed a set of hyperlights. I took off seat and then loosened the tail end and was able to get to a plug on the left side of the bike almost at the end of the tool tray. I tapped into the tail/brake light there. It's a plug but I don't think it looked like the one in your photo.
I believe there is another one that is located below the coolant tank / fusebox area but that one is a bit more difficult to get to IMO.
Jim
thecrumb is offline
post #3 of 10 Old 01-13-2019, 12:43 PM Thread Starter
Ok thanks. I'll take another look under the seat.
2017 DL650
YJGUY is offline
post #4 of 10 Old 01-13-2019, 01:11 PM
Mingo's Avatar
If you find it, please post pics. I have ordered that adapter from Eastern Beaver. Thanks.
Mingo is offline
post #5 of 10 Old 01-13-2019, 07:04 PM
The plug for the eastern Beaver auxiliary panel is near the rear brake pedal
Bob S.
2017 Vstrom 650 Base model (White)
2017 Yamaha YZ250X (Sold)....Hopefully WR250R soon
Previous loves:
1982 Yamaha 650 Seca
1978 Honda CB550
1975 Suzuki GT380
1977 Yamaha RD400
1973 Can Am MX1 125 (bought while Mom out of town)
Nicad is offline
post #6 of 10 Old 01-14-2019, 08:12 AM Thread Starter
Thanks! My bike is in storage and its super cold here (-18) so haven't had chance to really take a hard look. I'll see if I can find that one night this week when it warms up a bit.
2017 DL650
YJGUY is offline
post #7 of 10 Old 02-09-2019, 04:52 PM
Mingo's Avatar
I received the EasternBeaver tail light kit and it looks like your ViziTec won't work, as the '17 and newer have a different tail light harness
Mingo is offline
post #8 of 10 Old 02-09-2019, 08:32 PM
Brockie's Avatar
Unless they changed in 2017 the wires that you are looking to intersect with are yellow with a green stripe (pwr) and white with a black stripe (earth).
Brockie is online now
post #9 of 10 Old 05-07-2019, 07:30 AM
What did you end up finding on this? I just got a SupaBrake II and am trying to figure out where to plug it in on my 2017 Wee. The plug for the brake light is kind of triangular, but that isn't what my SupaBrake came with.
BasicJim is offline
post #10 of 10 Old 05-11-2019, 10:08 PM
Umbrianissimo's Avatar
@YJGUY
The Canadian 2017 Stroms seem to have the 2018 wiring harness. The white connectors on the bike are 4 pin, whereas most expect the 2017 to have a 5 pin connector. So you may find satisfaction getting a 2018 wiring harness / adaptor.
The black plug, with the blue centre portion that @Mingo shows, connects to the tail light unit, at the back of the bike, under the plastic. Rack and related plastic needs to come off. The plug on the light is at the right rear, as you sit on the bike. It is very hard to get your hand in to unplug the existing harness. It gives power, where as the 5 pin connectors seems to have one pin for power.
I ran into a similar dilemna with an Admore LED light bar on my Cdn 2017 650.
Damon
2017 DL 650 and maybe another Vespa?
I'm having an adventure- so, its an adventure bike.
Now that summer is here, I'm retiring so I can ride full time.
Umbrianissimo is offline
Brake light quit working rickpcmp3 DL650 and DL650A - 2004 to 2011 6 10-24-2015 09:42 PM
Replace stock brake light? worth it? strombastic DL650A - 2012-2016 22 09-22-2015 09:19 PM
Intermittent brake light - problem at the front brake connector maz_norcal General V-Strom Discussion 1 07-09-2015 10:35 AM
Brake light flasher Mastery DL650 and DL650A - 2004 to 2011 6 07-19-2014 10:11 PM
