Hazard light on 2017+ DL650? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 01-06-2019, 09:26 PM Thread Starter
Adventure Traveler
Kankujoe's Avatar
Not sure why Suzuki decided not to have hazard light on the USA version of the 2017 & 2018 DL650As. I believe elsewhere in the world they are still standard.
I occasionally have the need to use hazard lights. In heavy rain, in moderate fog, in construction zones, etc.
Is there an option of adding them to the Wee3? Is sufficient electrics available on stock to add a hazard switch?
Joe
2012 DL650-ADV (Black), 2013 DL650-EXP (White), 2013 Honda CRF250L, 2008 Yamaha TW200
IBA #55242, SS1000 x2, BB1500, SS2000, 50CC, National Parks Tour x5 w/ Silver & Gold, 4 Corners & Alaska, 48 plus one, Great Lakes.
Ad-ven-ture: 1. an undertaking involving risk, unforeseeable danger, or unexpected excitement. 2. an exciting or remarkable experience. Trav-ell-er: 1. one who seeks to experience their world. 2. one who seeks to be immersed in other cultures.
Kankujoe is offline
post #2 of 4 Old 01-06-2019, 10:59 PM
Hazzards have been added to the '19 so parts should be soon available.
brock29609 is offline
post #3 of 4 Old 01-07-2019, 07:15 PM
#motoref
TheCondor's Avatar
While I don't think you should be riding in the rain with hazards on (if you think you need, them park - and it's illegal in some states)
I do... when working bicycle races ... need them, so I modified my bike. It's SUPER simple to make them work.
You need to find the non-ground wire going to each turn signal (right and left). Splice a wire in between them - with a switch. Turn the switch on, turn your turn signal on ... and they all flash.
It's a little ghetto - but it does work (I did mine under the seat, but if you look under the beak, you can see the wires, it woudl be REALLY easy to mount a switch where you could reach it while riding. I keep saying I'm going to do that....
Scott Patton
2017 Vstrom DL650A XT
Givi Trekker Dolomiti Cases, SW-Motech Centerstand
Adventure Tech Fork Brace, Customized 4-way Flashers
Adventure Tech RAM Mirror Extenders w/RAM Mounts
Clearwater Darla Light
TheCondor is offline
post #4 of 4 Old 01-07-2019, 08:53 PM Thread Starter
Adventure Traveler
Kankujoe's Avatar
While my preference would be not to ride in the rain, it is not only a matter of stopping. You have to be somewhere you can safely stop or safely get off the road. Flashing hazards while stopped or slowing to get off the road lessens your chances of being run over. Same with fog.
Thanks for the technical info about a work around. Does this allow your turn signals to still work correctly?
Joe
Kankujoe is offline
2012 to 2016 DL650 Light Bar richlandrick AdventureTech LLC 27 05-06-2018 03:16 PM
2017 DL650 accessory part numbers johnfoxllb DL650A - 2017+ 11 12-19-2017 04:28 PM
SV650 front wheel installation on a DL650 exploring/carolina V-Strom Modifications and Performance 53 06-12-2014 02:54 PM
New camp light/trouble light penny mod docsabre Maintenance, Tech and Products. 0 06-28-2011 05:26 PM
