2017 DL650+Headlight relays - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 8Likes
post #1 of 12 Old 12-18-2018, 08:46 AM Thread Starter
rooster shooter's Avatar
So I've been reading up on the issue of headlight, (or is it starter switches) burning out on previous models due to high current flowing thru them. They apparently are not heavy enough to withstand the power draw. Do current models of 2017+ suffer this same malady? I've read of the various solutions that Eastern Beaver offers and quite frankly it's a lot to take in.
On a more pleasant note, farkles start arriving today.
'13 GL1800
'17 DL650A
rooster shooter is offline
post #2 of 12 Old 12-18-2018, 01:15 PM
nvr2old's Avatar
I'm sure the newer(Single headlight) models would still benefit from a relay, but with half the draw(55W versus 110) problems are a lot less likely. After some problems I put the relay on my 05. Don't think I will on the 18 1000. LED's lower the risk also(Less draw).
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
for the safety of existence.
nvr2old is online now
post #3 of 12 Old 12-18-2018, 02:40 PM
blaustrom's Avatar
As far as I can see EB is not offering a headlight relay kit for the V2 (single headlight) and the new 650.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #4 of 12 Old 12-18-2018, 05:18 PM Thread Starter
Thanks. That website is not the easiest to comprehend. Everything is lumped together and seems to take for granted that everyone knows the ins and outs of the VStrom.
Mingo likes this.
'13 GL1800
'17 DL650A
post #5 of 12 Old 12-19-2018, 12:53 AM
If you don't want to use an led headlight, then you could order the EB relay with the H4 plug and find a H4 to H7 adapter.
Hatchi is offline
post #6 of 12 Old 12-19-2018, 04:01 AM
Put a LED bulb in to the H9 high beam and leave low beam alone.
Not perfect but a lot better than stock and no messing around.
Mingo and Rollin' like this.
PeteW is offline
post #7 of 12 Old 12-19-2018, 08:37 AM
Mingo's Avatar
Does the entire dashboard need to be removed to access the high beam bulb?
Rollin' likes this.
Mingo is offline
post #8 of 12 Old 12-19-2018, 08:51 AM
Rollin''s Avatar
That is what I did. Haven't had a chance to do much riding with this setup but I think it will be a good option.
rooster shooter likes this.
Rollin' is offline
post #9 of 12 Old 12-19-2018, 08:52 AM
Rollin''s Avatar
No. Nothing has to be removed.
Rollin' is offline
post #10 of 12 Old 12-19-2018, 09:21 AM Thread Starter
What bulb is that? Are you the same Rollin' over on ADV that rode the Vic to Alaska?
Rollin' likes this.
'13 GL1800
'17 DL650A
Has Owning My DL650 Saved Money ? XLonDL650 General V-Strom Discussion 48 09-10-2018 11:23 PM
2016-16 DL650 aero vs 2017 Nicad General V-Strom Discussion 0 08-28-2018 07:20 PM
Upgrade from 2007 DL650 to 2017 DL650 H8-3Putts General V-Strom Discussion 27 07-13-2018 05:14 PM
Puig crash bars on DL650 XT 2017 lucsali DL650A - 2017+ 3 07-01-2018 07:06 PM
2017 DL650 Farkles That Fit richlandrick AdventureTech LLC 0 06-18-2017 10:38 AM
