Old shocks on new model? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 12-14-2018, 08:21 AM Thread Starter
#motoref
TheCondor's Avatar
I cant find any info to prove they will or wont work. There is almost NOTHING available for 2017 with a part number, to compare to older bikes.
Anybody figured it out?
Scott Patton
2017 Vstrom DL650A XT
Givi Trekker Dolomiti Cases, SW-Motech Centerstand
Adventure Tech Fork Brace, Customized 4-way Flashers
Adventure Tech RAM Mirror Extenders w/RAM Mounts
Clearwater Darla Light
TheCondor is offline
post #2 of 3 Old 12-14-2018, 10:04 AM
How old?
I researched the reverse question (new shock on old model) to see if I could ship a friend my '17 shock to use on his '09. It worked. The only small mod he had to make was to slightly enlarge the mounting holes for the remote preload adjuster.
However, I believe I read that Suzuki improved the shock and increased travel starting with the Gen2 models. So if you get a Gen1 shock it'll slightly lower your bike and ride crappier. Gen2 and Gen3 should be the same shock, except for perhaps different colors.
Double check all this. Going by memory, but I believe it's all true.
brock29609 is offline
post #3 of 3 Old 12-24-2018, 07:01 PM
ddphillips's Avatar
Hi, Installed ohlins shock from 2012 onto 2017, no issues.
Darren
2017xt 650 vstrom, yellow.
Ohlins SU216 rear shock, .85 fork springs, cogent DDC, Barret 3/4 exhaust, 20mm rear raising links, ricks fork brace, oxford heated grips, Radguard, Altrider bash plate & engine bars, Steel pony soft panniers and rack, TAG bars, foot peg lowering brackets, gear lever extension, bar end mirrors.
ddphillips is offline
Decision time: Buy an ADV (maybe even XT) or a bare model and build it myself? 2wheelsgood DL650A - 2012-2016 21 06-05-2015 07:48 PM
Changing Seat Tail Covers Hanadarko DL1000 from 2002-2012 9 02-20-2008 12:32 PM
US Model Differences Jim Davis General V-Strom Discussion 16 02-15-2008 06:02 AM
Dl1000 - which country's model is best? Jim Davis General V-Strom Discussion 3 11-30-2007 08:16 PM
